EVAP PURGE question
Old May 14, 2004 | 12:21 AM
Revolution2zz's Avatar
Default EVAP PURGE question
My setup as follows, currently doing the swap.
1992 Civic DX HB
2001 OBD2 B18C swap running a JDM 95 OBD1 P72 ECU.
Question is can just remove the EVAP purge selenoid completely and cap off the line to the TB? Will this throw a CEL? I don't wanna hassle with runnin another wire to A20 on my ECU. any help would be appreciated! Thanks
Old May 14, 2004 | 09:55 AM
built562's Avatar
Default Re: EVAP PURGE question (Revolution2zz)
you can unplug it and cap it off, the jdm ecu does not look for the evap purge solenoid so you will not get a CEL, its only to put air into the gas tank when gas is pulled out.
Old May 14, 2004 | 10:07 AM
dantastic's Avatar
dont all usdm 92-95 civics have evap purge solenoids? my 93 cx had one
arziffel
Feb 2, 2012 06:14 PM
andrew714
Dec 15, 2007 10:36 PM
quikflip27
Aug 3, 2007 11:23 AM
ctr status
Sep 14, 2006 05:10 PM
bb4socal
Jun 19, 2006 11:12 PM
