what stock honda throttle body fits b16a1?
Old May 14, 2004 | 12:10 AM
NINJASPY's Avatar
Default what stock honda throttle body fits b16a1?
what stock honda throttle body fits the b16a1 non-obd motor? Stock is 58 mm and I am wondering if any ls, gsr, h22 etc throttle body fits the stock b16a intake manifold.
I want stock honda because its nice a cheap
Old May 14, 2004 | 12:32 AM
Malgerus's Avatar
Default Re: what stock honda throttle body fits b16a1? (NINJASPY)
Type ARRRR
Old May 14, 2004 | 03:17 AM
RobbieG35's Avatar
12 Years Strong
Default Re: what stock honda throttle body fits b16a1? (Mr. S)
Any B-series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Type ARRRR</TD></TR></TABLE>
Yep 62mm, brand new its over $400 Can you say Spoon?
Old May 14, 2004 | 06:30 AM
tgreaves's Avatar
One from a d16a1 does..
Old May 14, 2004 | 08:27 AM
chadmasterc's Avatar
There is a guy in the sponsor marketplace that can bore your tb 4mm for 100$. I think its in the performance forum.
Old May 14, 2004 | 08:58 AM
Rywire's Avatar
Default Re: what stock honda throttle body fits b16a1? (chadmasterc)
http://www.gbronline.com/jorgep/index.html
Ryan
Old May 14, 2004 | 09:53 AM
Karterguy13's Avatar
I just bought a gsr one for mine and it's way diff. Something about the idle air controll valve or something
Old May 14, 2004 | 09:57 AM
BlueShadow's Avatar
Default Re: what stock honda throttle body fits b16a1? (Karterguy13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a gsr one for mine and it's way diff. Something about the idle air controll valve or something</TD></TR></TABLE>
Also the throttle cable pulley is backwards for the GSR.
GSR TB on the left, B18 (LS)TB on the right, also identical to the right are B16 and ITR TB's
Old May 14, 2004 | 09:58 AM
RobbieG35's Avatar
12 Years Strong
The IAC and map sensor should be different
Old May 15, 2004 | 06:41 AM
Xsi's Avatar
Xsi
I'm using an H22a 60mm tb on mine, had it bored out to 63mm
Old May 15, 2004 | 08:33 AM
Default Re: what stock honda throttle body fits b16a1? (BlueShadow)
I was told to put my throttle shaft in it so I could set the throttle cable up. I wanted to use that throttle body so I could have the mapsensor on it instead of the fire wall.
Old May 18, 2004 | 12:09 PM
soulstream's Avatar
I have an h22a throttle body if you're interested.... check my sig for pics.
Old May 18, 2004 | 01:42 PM
BERT-O's Avatar
ITR OR S2000, both are 62mm
Old May 18, 2004 | 01:46 PM
spaceman's Avatar
Default Re: what stock honda throttle body fits b16a1? (BERT-O)
itr or s2000 will work on a 1st gen obd0 b16?
Old May 18, 2004 | 02:47 PM
4gCRX's Avatar
Default Re: what stock honda throttle body fits b16a1? (spaceman)
Throttle body diameters: http://www.hondaswap.com/forum...29792
Old May 18, 2004 | 04:51 PM
HT Chaplain's Avatar
Loved
Default Re: what stock honda throttle body fits b16a1? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">http://www.gbronline.com/jorgep/index.html
Ryan</TD></TR></TABLE>
Does anyone have expierience with gbronline? It looks like those TB walls are really thin after being bored out. Would they crack after long period of time of hard driving? And what about the quality of parts that he uses to replace the original parts?
Old May 18, 2004 | 04:55 PM
Rywire's Avatar
Default Re: what stock honda throttle body fits b16a1? (legutki)
I JUST got mine back a few minutes ago, lol. Its SWEET!!!!! Very strong side walls, and new butterfly piece. He even sandblasts it, and recalierates the tps!!! Highly reccomended. So for 100 bux I just got a 64mm TB!! Ryan
PS, im stoked if you couldnt tell
Old May 18, 2004 | 06:06 PM
spaceman's Avatar
thats cool dood...do you think i could get mine done someday?
hlee5363
Nov 8, 2005 07:13 PM
high_revs
Oct 30, 2005 01:01 PM
JDMcivicRacing
Aug 5, 2005 01:59 AM
Que_Lude
Dec 24, 2004 02:12 PM
DXK Eg
Dec 19, 2004 09:50 AM
