Rear Disc Swap in Progress! E brake cables too short?!
Old May 13, 2004 | 11:28 PM
92b18cx's Avatar
Default Rear Disc Swap in Progress! E brake cables too short?!
Has anyone had any experience/problems with the ebrake cables when doing the rear drum to disc swap on an eg? Suppossedly everything is suppossed to bolt up without a problem. The rear trailing arms are from a Del sol, ( not sure which year) and the cables were from a 94 del sol. Well the cables are too short! I don't get it I thought this was suppossed to be bolt on? So right now I have no ebrake. And I still have the stock cx prop valve so braking doesn't feel all that different. The pedal still feels a little soft even after thorough bleeding.
Anyone have any idea what my problem is, why the cables are too short? Should I use Integra cables or civic si cables, any suggestions appreciated. thanks.
Old May 13, 2004 | 11:29 PM
Filliam H. Muffman's Avatar
Default Re: Rear Disc Swap in Progress! E brake cables too short?! (92b18cx)
use gsr cables
del sol too short.
seach before posting.
-Derek
Old May 14, 2004 | 12:01 AM
92b18cx's Avatar
Default Re: Rear Disc Swap in Progress! E brake cables too short?! (JUN EK9)
thanks for the info, I will try to exchange these. and I will search next time.....
gmcuajo1
Jun 22, 2014 07:23 AM
93 del slo
Aug 26, 2009 08:28 PM
94 ls teg
Jan 31, 2007 12:50 PM
CivicSiRracer69
Oct 25, 2004 08:34 PM
Slow Egg
Oct 6, 2002 09:29 AM
