Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
AEM Adjustable Fuel Pressure Regulators - In stock, Free Shipping!
Old May 13, 2004 | 10:04 PM
prostreetonline's Avatar
Default AEM Adjustable Fuel Pressure Regulators - In stock, Free Shipping!
These billet aluminum AEM fuel pressure regulators can support engines up to 1,000hp. Featuring replaceable discharge ports to match your fuel pump output, they're adjustable from 20psi up to the maximum pump capacity rating.
AEM's Adjustable Fuel Pressure Regulator is constructed of 6061 T-6 billet aluminum and is capable of support enough fuel flow for engines in excess of 1000 horsepower. Only AEM regulators have replaceable discharge ports which allows the user to tailor the regulator to the output of ANY fuel pump, whether it be the stock unit or a high flow aftermarket pump. For the Honda/Acura AFPR's, the base of the regulator is tapped to accept the stock hose barb fitting or an AN fitting. For the Universal AFPR's, the regulator's inlet and outlet ports are tapped to accept either -6 or -8 lines.
Key features:
Only AEM Adjustable Fuel Pressure Regulators have replacable discharge ports to match regulator and fuel pump output
For custom fit applications, mounts directly to stock or AEM High Volume Fuel Rail
For Universal applications, can be remotely mounted for use on all vehicles
Adjustable from 20psi to maximum fuel pump capacity rating
Available in blue, red and silver with laser-etched graphics for show-quality looks. Specify in special instructions when ordering.
Manufactured and assembled in the USA
Patent Pending
Click here to order:
http://www.prostreetonline.com...ators
Other specials:
http://www.prostreetonline.com...h.asp
envision
Aug 26, 2015 02:00 PM
si90rex
15
May 18, 2010 05:03 PM
bsprelude
Dec 8, 2004 12:52 PM
