So what's everyones trick to stop the flywheel from turning when changing your clutch out ?
Just spent a whole lotta time pulling my d-series out and prepping my newmotor, was going to pull the clutch/pp/fly tonight since I have a new clutch but I haven't looked at how I'm going to stop the flywheel from turning when I undo the pp bolts since I'm tired as hell...whats the trick with hondas ?
I searched also, couldn't really find anything...just people saying it's easy to change a clutch heh
when i took my clutch off, i put the bolt i was taking off at the top of the flywheel so then when i pull up on it, it doesnt spin. same thing with tightening them
Guest
Posts: n/a
take a ratchet and socket and put it on the crank pulley. put a long hollow pipe on the handle of the ratchet to make a sort of extension for the handle. rest the new "handle" on the floor, that should lock it from turning.
Put one of the tranny bolts into the motor and use a prybar to lock against that bolt and one of the flywheel teeth..
http://www.c-speedracing.com Clutch Install - Put a large screw driver against one of the transmission dowels, and stick the head in between two teeth.
Basically the same thing as this:<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Put one of the tranny bolts into the motor and use a prybar to lock against that bolt and one of the flywheel teeth..</TD></TR></TABLE>
snap on makes flywheel holders or like evryone else said get the crank pulley tool and brace it against the floor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FwdCivicHatch »</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com Clutch Install - Put a large screw driver against one of the transmission dowels, and stick the head in between two teeth.
Basically the same thing as this:</TD></TR></TABLE>
I dont use the dowel pins because I bent one once holding it still.. But yes either way will work..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjoback »</TD></TR><TR><TD CLASS="quote">blam
I got the same tool, worth every penny from acura
In my tired state I forgot I had a crank pulley tool lying around from my old civic, so I digged it up and used it...everythings off now. Thanks for all the good suggestions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">
I got the same tool, worth every penny from acura</TD></TR></TABLE>
Part number from acura?
-PHiZ
-PHiZ
eK_HatchY
12
Dec 31, 2009 09:45 PM
AccordCoupe
Mar 25, 2003 10:05 PM
worked time and time again
