What can I do to make my LS motor run harder?
Old May 13, 2004 | 09:30 PM
RedEG-6's Avatar
Default What can I do to make my LS motor run harder?
What up peeps? I was wondering what could I do to make my LS(B18B1) motor run harder? I already have bolts ons, Intake, 4-2-1 Header, 2 and 1/4 straight exhaust piping with an aftermarket resonator and Magnaflow muffler, B&M Fuel regulator with gauge, and MSD Ignition wires. I was thinking of buying a B16 transmission if i can get my hands on one. Can anyone give me some advice, I want to hear what everyone has to say.
Old May 13, 2004 | 09:43 PM
HondaGuy02's Avatar
Banned
Default Re: What can I do to make my LS motor run harder? (RedEG-6)
whats up, welcome to honda-tech dude
People tend to get mad about post's like this one so be sure to use the SEARCH link .
Alot of topics have been covered many times and a lot of the same questions have been answered many times.
If your unsure about what to do with your car then just do some research, find out for yourself what route you wanna take.. turbo, NA, NOS... ect. ect.
Old May 13, 2004 | 09:47 PM
HondaGuy02's Avatar
Banned
Default Re: What can I do to make my LS motor run harder? (HondaGuy02)
me personally, i would probably do some head work with some cams and pick up a nitrous express kit.
Old May 13, 2004 | 09:49 PM
Dan GSR's Avatar
b16 trans
i have one on my LS , and it transformed the car, also get lightweight flywheel
Old May 14, 2004 | 06:33 AM
RedEG-6's Avatar
I was thinking about getting a wet kit, but if i do how much should i spray and should i finish getting the entire MSD Ignition system? i heard it helps the motor from detonating.
Old May 14, 2004 | 10:15 AM
crxracer2's Avatar
man get the b16 tranny and the flywheel if u can like dan GSR said he knows wut he is talkin about that **** will pull harder then later sleeve and bore it out to 84mm and get some high compression pistons or some cams
Old May 14, 2004 | 10:23 AM
dclsvtec's Avatar
do the tranny work with clutch lsd and all that fun stuff. or you can go lsvtec it pulls, mine did. it just pulls more on the freeway not realy on take off cause mine has the vtec crossover like at 5800 but youll feel the low end power too. if you wanna stay ls do head work and tranny work and mabe bore it out for better torque.
Old May 14, 2004 | 10:28 AM
Used2beAb16's Avatar
Default Re: What can I do to make my LS motor run harder? (dclsvtec)
b16 tranny, more compression, more displacement, more cfm, bigger cams, and tuning will make your motor run harder.
Old May 14, 2004 | 07:37 PM
RPRacing's Avatar
buy my LS head that has been milled .030"
boosted k20
Jul 19, 2005 09:05 PM
phylast
Sep 5, 2004 10:09 AM
Greenery18
Jun 29, 2004 05:49 PM
JdmLsPwr425
Jun 24, 2004 09:19 AM
nitrotiger
Jan 7, 2004 07:41 PM
