Adding a VTEC head to D series non vtec engine.....
Old May 13, 2004 | 09:08 PM
powerslide360's Avatar
Default Adding a VTEC head to D series non vtec engine.....
I was wondering what exactly I would have to do to switch my non vtec D series engine over to a SOHC VTEC engine. I have the complete head, intake manifold, distributor, ecu, everything. where do I run the VTEC oil lines? what wiring do I have to do? please, help me......thanks!
Old May 13, 2004 | 09:38 PM
Redline130's Avatar
Default Re: Adding a VTEC head to D series non vtec engine..... (powerslide360)
Search under "mini me", you will find ton's of info. Also, you don't need to run an oil line for a D-series VTEC head swap.
Old May 14, 2004 | 07:30 AM
tgreaves's Avatar
No vtec line.. There is an oil control jet on the block that you pull out and then its a vtec block..
Old May 15, 2004 | 08:52 PM
how hard is it to wire everything up? I have the SOHC VTEC ECU -- should I get the wiring harness too? what do i gotta use, I'm not too good with electrical stuff.....thanks!
Mauro Gelbert
Mar 3, 2016 02:03 PM
redrix
Apr 21, 2013 01:06 AM
scspeed
Jan 5, 2011 08:13 PM
sicivic
Aug 7, 2004 05:55 AM
