GSR swap... A/C problem
I jus swapped a 94' GSR engine into my 94' Civic coupe. I'm triying to get my Ac working but the hoses don't fit. My hoses are from the original civic and i think my compressor is the Integra's. My "low" is not a problem but it's the "high" hose that won't fit properly without twisting the hose and puttin a knottin in it. What are some solutions that i can do inorder to get my ac up and running? Is it even possible to even have AC? I need some help asap... It's gettin Hot and very humid in Michigan...
i think you need to use the civic compressor....and use a p54 del sol dohc vtec bracket....well thats what i did on my girls hatch....
not sure if the integra bracket works on the civic lines...bump for some help..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">reuse your civic compressor
and get a dohc vtec del sol ac mount</TD></TR></TABLE>
i have the same problem. does this deffinatly work?? the stock sohc compressor bolts up to the dohc vtec del sol a/c mount? bump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchy92 »</TD></TR><TR><TD CLASS="quote">use the civic compressor. Only 2 bolts will work with the GSR bracket. Del sol is recommended. Im still running the GSR bracket, still holding strong!</TD></TR></TABLE>
that sounds cheaper and easier, ill do that
JinDIESEL
Sep 3, 2004 05:54 AM
boomslang
Jun 21, 2002 11:54 PM
