question for anyone with a boosted 6th gen
Old May 13, 2004 | 08:47 PM
h22abuyer's Avatar
Default question for anyone with a boosted 6th gen
hey, I have a question for anyone with a boosted 6th gen 4cyl. what are you guys using for fuel management. I have a kit that came with the two extra injectors and an FMU. is this sufficient to safely boost at 5 psi? if you don't think so, what would you suggest, I am under no real time constraints to get this all done, so i would be willing to look around for any parts you would suggest. also, if the set-up i described should be safe, don't send me on a spending spree please.
Old May 14, 2004 | 04:55 AM
notoriousB's Avatar
Default Re: question for anyone with a boosted 6th gen (h22abuyer)
two extra injectors AND an FMU? What's there to control the extra injectors?
you can use one of those (if something's there to control the injectors) but not both
I ran an FMU/inline pump/missing link combo for ~ 7 months or so, it's safe as long as you use the inline pump (A/F checked on a dyno w/ wideband), but I've since switched to the AFC hack and it's much better
Old May 15, 2004 | 11:43 PM
h22abuyer's Avatar
Default Re: question for anyone with a boosted 6th gen (notoriousB)
ya, there is an injection control system for the extra injectors. i will only keep this system until i can get some bigger primary injectors and an E-manage system.
BlUAc
Jun 7, 2006 08:35 AM
spoon95eg
Dec 19, 2005 06:15 PM
boostedlude3g
May 26, 2004 01:43 AM
TURBOED-TEG
May 8, 2002 06:33 AM
Giuseppe
Oct 10, 2001 09:23 PM
