best street clutch???
http://www.clutchmasters.com
These guys have the best stuff out for the street cars of TODAY, from stock to full race check them out. PLus the guys over there are very helpfull.
Good luck
Good luck
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
for those out there that wish to have the end all be all of clutches check out RPS TURBO CLUTCH! this is the new clutch that i will be running in both of our allmotor race cars. NOT FOR THE faint hearted or budget challenged but by far the most technologically advance clutch designs PERIOD!www.TURBOCLUTCH.COM
THESE GUYS ARE THE ONLY COMPANY INCORPORATING SEGMENTED FORMULA ONE TECH INTO THEIR CLUTCHES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16vtecsol »</TD></TR><TR><TD CLASS="quote">just like it says guys. what clutch, in your opinion, is best for the street?</TD></TR></TABLE>
Back to the question at hand - street? I would have to stick with the CM stuff they offer a huge range of set ups.
I just got my action 2md, and it's kinda hard to start off on the street, but it sure does grab. Try action, I'm not sure which one it is, but they have a 6puck sprung clutch.(as opposed to mine which is unsprung)
Guest
Posts: n/a
i fun a custom 6 puck, unsprung disk with an ACT Xtreme PP....its a bit much for most ppl......and a bit overkill unless you're like me and running 24.5's
Action, Clutchmasters, ACT, exedy, etc....etc..... all make "street" clutches...and not one is better than the other...cept Spec clutches, they are complete CRAP.
the best thing to do is drive some friends cars that have different clutches..and find one that you think feels "right" and get it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">ACT street/strip disc w/ good pressure plate.</TD></TR></TABLE>
i agree
i agree
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 71 mgb »</TD></TR><TR><TD CLASS="quote">exedy organic street is a nice upgrade for steet.. </TD></TR></TABLE>
I've had 3 of these in 3 diffrent cars. I like 'em. just my $.02
DYNO-PRO
as i said if you want the best go RPS if you are looking for a good economical street clutch i would reccomend the EXEDY 08950b kit they are great clutches and handle up to 280 WHP. they have also been around for a LONG time. the 08950b is a 3 puck sprung hub design, we have used them on numerous allmotor setups and have had great luck with them. WE retail the kit for $295.95
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">as i said if you want the best go RPS if you are looking for a good economical street clutch i would reccomend the EXEDY 08950b kit they are great clutches and handle up to 280 WHP. they have also been around for a LONG time. the 08950b is a 3 puck sprung hub design, we have used them on numerous allmotor setups and have had great luck with them. WE retail the kit for $295.95</TD></TR></TABLE>
hmmmm......might have to check out ur website
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. »</TD></TR><TR><TD CLASS="quote">Action, Clutchmasters, ACT, exedy, etc....etc..... all make "street" clutches...and not one is better than the other...cept Spec clutches, they are complete CRAP.</TD></TR></TABLE>
I would have to disagree that "not one is better than the other". While there is "some truth" to it, it certainly needs some clarification. A clutch is comprised of two basic sub systems: the pressure plate and the clutch disc.
The pressure plate gives you your pedal "weight", or how hard the pedel is to press. The pressure plate also determines your clamping force. This comes down to a compromise between pedal weight and clamping load, because as one increases so does the other. I like CM pressure plates because they change the fulcrum point, which allows them to increase the clamping load, but still maintain a stock like pedal weight. Ultimately if the clamping load is the same, then a pressure plate is a pressure plate. The only difference may be the pedal weight.
The clutch disc is the primary driver for the durability and engagement characteristics of the clutch assembly itself. The clutch disc is where companys seperate themselves. Organic disc provide the best "street" clutch, but they do not fair well with heat and wear rapidly with aggressive use, but they provide smooth engagement with no chatter, with excellent ability to "feather" the clutch. Most organic discs will simply be rebadged OEM clutch discs, with the only change being the springs may have been upgraded. Beyond organic discs is where you get into metalic based discs and ceramic/composite based discs. Metallic based discs will provide the heat resistance and resistance to abuse, but often suffer severly with regard to engagement characteristics, resulting in possible chatter, not feathering, etc. My recommendation for an aggressive street disc is to stick with ceramic/composite based discs. These disc are generally a good comprimise between organic and metallics. I personal recommend the CM Carbon/Kevlar based discs. The offer aggressive clutch engagement, but can still be feathered, though not as smoothly as organics. They offer good heat resistance and provide excellent durability and long term use.
Segmented clutch disc increase torque capacity of the clutch, but sacrifice engagement characteristics.
For a street clutch I recommend that you get a sprung disc too.
DYNO-PRO
we are currently working on a HUGE WEBSITE for our shop it is taking for ever for now please contact us at the shop 909-373-RACE (7223) keep checking back to the website someday we will finish this damn site http://www.HOOKUPSIMPORTTEK.COM please remember that it is TEK not TECH
bubbajim
Feb 16, 2003 03:57 PM
