strugglin civic needs much helps
Old May 13, 2004 | 07:23 PM
itrhopeful's Avatar
Default strugglin civic needs much helps
my car (93 ex coupe) is having many struggles. the radiator's done, the cooling fan doesn't kick on and there's a crazy noise that comes from the area where i think the cam gears are. (there's some sort of shroud or heat shield around it so i can't see what it is but that's where it should be.
anyways the radiator part i'm fixing but that sound is another story. it starts out like something is spinning of center then it gets to be a clacking noise. if anyone has any ideas let me know
Old May 13, 2004 | 07:46 PM
Discosteak's Avatar
Default Re: strugglin civic needs much helps (itrhopeful)
t-belt/water pump check them both
Old May 16, 2004 | 09:34 AM
itrhopeful's Avatar
Default Re: strugglin civic needs much helps (BADEG6)
how would i know if it's the water pump? i'd rather be able to rule that out first if i could fix it myself. i kknow the timing belt would be a mess to work on. but i don't know about the water pump. anyways the sound is off and on now and it's much quieter than it was before. once i got the coolant flowing in there and got it into vtec again the noise peaked and then stopped altogether. i have heard it a little bit since then but no where near as loud as before. thanks for the post too.
Old May 26, 2004 | 01:37 PM
itrhopeful's Avatar
Default apparently i'm out of my head
yeah, so i just checked with my mechanic and my head gasket is f'ed. does anyone know of a step by step guide for a red gasket replacement? i also plan on changing the t-belt and water pump while i'm in there. does the haynes manual have that sort of thing in it? (why do i think that's a stupid question) anyways i really need to know if this can be done in a saturday? cause that's pretty much all i have. PLEASE HELP ME!
i'm also thinnking about if i do indead need a new head what head could i find easily that would match, compliment, improve, or just plain make it friggin' work!
anything would help. thank you all.
mooploops
Jul 29, 2009 11:42 AM
fryman
Aug 22, 2008 10:31 AM
fireant
May 18, 2008 03:35 PM
Ge-money
Sep 6, 2006 02:55 PM
bobbyh
Mar 30, 2002 12:39 AM
