New Big Brakes for the car...teaser
Old May 13, 2004 | 07:17 PM
Austin's Avatar
Default New Big Brakes for the car...teaser
Here is a little picture...still need to take care of a few things...
'90-91 EX knuckles
'92-96 Prelude 11.1" rotors, redrilled to 4X100
Type-R calipers
Some grinding necessary....need to take pictures of the grinding, next time I'll have pics of it installed.
What else gets installed...
1" MC
Integra booster
new prop valve
Old May 13, 2004 | 07:39 PM
b16_madman's Avatar
Default Re: New Big Brakes for the car...teaser (Austin)
does the prop valve control the pressure of the brake pistons left and right? by chance? or should I look elsewhere for uneven braking pressure, sorry 2 threadjack
Old May 13, 2004 | 08:20 PM
Jonathan_ED3's Avatar
That's awesome!
I'll be there soon, but probably with NSX or Legend calipers.
Did you do the 4x100 redrill, or have a shop do it?
Modified by Jonathan_EH at 11:47 PM 5/13/2004
Old May 13, 2004 | 08:29 PM
sporkcrx's Avatar
Default Re: (Jonathan_EH)
good stuff austin
Old May 13, 2004 | 09:39 PM
chri5's Avatar
Default Re: (sporkcrx)
Austin always has the coolest stuff.
Old May 14, 2004 | 03:31 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (Strng1dah)
Very cool, stopping power yo!
Old May 14, 2004 | 09:54 AM
Driven's Avatar
Default Re: New Big Brakes for the car...teaser (B16_madman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">does the prop valve control the pressure of the brake pistons left and right? by chance? or should I look elsewhere for uneven braking pressure, sorry 2 threadjack</TD></TR></TABLE>
Prop valve controls front and rear bias, iirc.
if you have uneven left/right brake bias, then you might want to check the lines and calipers.
hth
Old May 14, 2004 | 10:32 AM
b16_madman's Avatar
Default Re: New Big Brakes for the car...teaser (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">if you have uneven left/right brake bias, then you might want to check the lines and calipers.
hth</TD></TR></TABLE>
k, i thought that's what the prop valve controlled, lines are new, one caliper is newer than the other, i guess the drivers side is ragged out now, might just replace both at the same time
Old Jan 8, 2005 | 11:53 PM
Black R's Avatar
25 Year Member
.....do the siR knuckles or 91 ex knuckles have mounting points for abs sensors?
Old Jan 9, 2005 | 12:31 AM
jisu009's Avatar
I rock the exact same setup on my street kaa
Old Jan 9, 2005 | 12:43 AM
rice_classic's Avatar
Default Re: New Big Brakes for the car...teaser (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">I rock the exact same setup on my street kaa </TD></TR></TABLE>
And don't your rotors warp every other week?
Old Jan 9, 2005 | 04:48 AM
ne3ek's Avatar
Default Re: New Big Brakes for the car...teaser (rice_classic)
what year integra powerbooster is used? 90-93?
Old Jan 9, 2005 | 09:07 AM
cursED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">Some grinding necessary....need to take pictures of the grinding...</TD></TR></TABLE>
I had mine done at a machine shop. Removal is .115 to .118 inch (apx. 3mm).
_
Old Jan 9, 2005 | 10:48 AM
bossman032's Avatar
Default Re: New Big Brakes for the car...teaser (cursED)
dam those are some huge brake rotors lol..
do you really need a 3000lb cars stopping power..??
Old Jan 9, 2005 | 11:18 AM
CRXBart's Avatar
Default Re: New Big Brakes for the car...teaser (bossman032)
Here you go buddy, been there done that.
I did mine with no grinding necesary when I did the type-r calipers, w/prelude Rotors, and Kosei K-1's
http://home.wideopenwest.com/%7Etschmidt/index.htm
Or here.
https://honda-tech.com/zerothread?id=1003573
Old Jan 9, 2005 | 11:44 AM
cr-x-91's Avatar
Default Re: New Big Brakes for the car...teaser (CRXBart)
crx bart. on your write up it says that u cant use the civic ex mc 15/16 cuz they have diff bult pattern. im using the 15/16 off the 91 civic ex. i did the same swap but stayed with the 10.3 setup. im running the 91 si rex prop valve also.
Old Jan 9, 2005 | 06:27 PM
cursED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I did mine with <u>no grinding necesary</u> when I did the type-r calipers, w/prelude Rotors, and Kosei K-1's</TD></TR></TABLE>
Have you tried fitting the ITR calipers under factory 15" wheels without milling the caliper bracket (I'm talking about where it <u>attaches to the knuckle</u>, as per the picture I posted above)? Did you run into any clearance issues with the inside of the wheel, or uneven pad wear?
I'm asking this because the clearance with that setup & the factory wheels is very tight. I have had the 15" Si wheels, and two different sytles of 15" integra wheels mounted with that setup.
I also went through 2 sets of pads & rotors. Pad wear was normal - in fact, I still have my old pads.
I now run the 94+ rotors/calipers on EX knuckles (which I would agree there is no machining necessary on those, including of course the EX brake setup).
Old Jan 9, 2005 | 06:51 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cursED &raquo;</TD></TR><TR><TD CLASS="quote">
I now run the 94+ rotors/calipers on EX knuckles (which I would agree there is no machining necessary on those, including of course the EX brake setup).</TD></TR></TABLE>
You know what you are right, I almost forgot about it. I did grind the caliper mounting plate. Where the mounting threads are, it edges out about 1/4" I grinded that flat, then it fit right up. I just used a bench grinder, and a belt sander to grind it smooth.
Old Jan 9, 2005 | 07:08 PM
Rostr02's Avatar
wilwood 4 piston calipers for me
Old Jan 9, 2005 | 07:27 PM
DocSean's Avatar
Default Re: New Big Brakes for the car...teaser (Rostr02)
Does a brake upgrade of this kind only work with EX knucles? What can a guy do with the si/dx knuckles? (I have a swapped HF)
Old Jan 10, 2005 | 03:52 AM
CRXBart's Avatar
Default Re: New Big Brakes for the car...teaser (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">Does a brake upgrade of this kind only work with EX knucles? What can a guy do with the si/dx knuckles? (I have a swapped HF)</TD></TR></TABLE>
fastbrakes, other than that upgrade to ex knuckles.
Old Jan 10, 2005 | 09:00 AM
nautica_t's Avatar
Default Re: (Jonathan_ED3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">That's awesome!
Modified by Jonathan_EH at 11:47 PM 5/13/2004</TD></TR></TABLE>
Aren't NSX calipers like 7lbs each??? from what i heard?? thats goign tob e some heavy brakes
Old Jan 10, 2005 | 09:24 AM
89dxhunchback's Avatar
Default Re: (nautica_t)
I'd swap to the NSX calipers and lude rotors if they were cheap enough ( which is kinda impossible ).
On the other hand...
I saw on "sports car revolution" that they lost something like 10whp by upgrading the brakes on there mugun project acrua RSX-S, and that's not counting the weight of the caiplers, that's just power lose from increased rotor size.
But you gotta stop before you can go...
I choose a cheaper, more "in the middle" route. 10.2 inch DA brakes all the way around ( 9.5'' in the back ) with steel braided lines. Still waiting on the MC/brake booster to come in the mail, which is also off a DA.
The legend calipers are deffinately going to look huge from what I've seen pics of, but your still only going to be able to stop as fast as your tired let you, so I hope you have some toyo prox RA-1s...
Old Jan 10, 2005 | 10:06 AM
CRXBart's Avatar
Default Re: (89dxhunchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote">I'd swap to the NSX calipers and lude rotors if they were cheap enough ( which is kinda impossible ).
The legend calipers are deffinately going to look huge from what I've seen pics of, but your still only going to be able to stop as fast as your tired let you, so I hope you have some toyo prox RA-1s...</TD></TR></TABLE>
If I could do it again, I would probally just do 10.2" EX brakes on my REX. As it stands now, w/ the lude, accord wagon, civic ex hybrid, I can only fit 15" wheels, which kinda blows. I'm sure cutting down that mass on the outer diameter would help also, but nothing beats jambing those bitches on at like 85 with no brake fade, and breaking your occupant's collar bone. I love doing that test on people.
Old Jan 10, 2005 | 11:04 AM
1boostedhybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">Here is a little picture...still need to take care of a few things...
'90-91 EX knuckles
Type-R calipers
1" MC
Integra booster
new prop valve
</TD></TR></TABLE>So what did you do Austin? Pull your old ITR brakes off and mod them for the rex? So what is your R stopping on now? BTW I found some OLD pics of your first R at Sac raceway. I still love the shots of those Mugen's....
Marc
