Exedy CLUTCH - what is the difference between thick and thin..?
Old May 13, 2004 | 05:55 PM
Super_Eg6's Avatar
Default Exedy CLUTCH - what is the difference between thick and thin..?
I have a #08900B which is the thin plate and my friend has a #08950B which is the thick plate. What is the difference? And does anyone know how long it last, pressure etc? Also does anyone know how offen an aluminum flywheel last (flex to heat, wear etc)? thx
Old May 14, 2004 | 07:34 AM
tgreaves's Avatar
Default Re: Exedy CLUTCH - what is the difference between thick and thin..? (Super_Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">I have a #08900B which is the thin plate and my friend has a #08950B which is the thick plate. What is the difference? And does anyone know how long it last, pressure etc? Also does anyone know how offen an aluminum flywheel last (flex to heat, wear etc)? thx</TD></TR></TABLE>
The thin will spin up faster when you shift gears making it eaiser on your syncros because the disc is lighter.. The think has better resistance to heat from what im told..
Old May 19, 2004 | 10:26 PM
Super_Eg6's Avatar
does one last longer than the other? i have the thin one and after 5000 miles, i can pull my car out of gear with out the clutch pedal down...EASILY, with almost no force!!!! is this bad?
Old May 20, 2004 | 05:25 AM
tgreaves's Avatar
Default Re: (Super_Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">does one last longer than the other? i have the thin one and after 5000 miles, i can pull my car out of gear with out the clutch pedal down...EASILY, with almost no force!!!! is this bad?</TD></TR></TABLE>
I sure the **** hope not.. I just put one in my car.. Did you let it break in properly and all that.. Also are you doing alot of street driving..
Old May 20, 2004 | 05:07 PM
Super_Eg6's Avatar
yea i did, at i put at least 1000 miles before i even punched it for the first time, the clutch right now has 5k miles on it....you think my flywheel (lighten ACT aluminum i think) warp or anything?
Old May 24, 2004 | 11:20 AM
tgreaves's Avatar
Is the milling on the flywheel correct for the exedy clutch??
94DB8
Feb 1, 2008 07:55 AM
crowder13
Jan 14, 2008 01:56 PM
methanemotorworks
Feb 13, 2006 07:32 PM
meltman1234
Sep 23, 2005 11:45 AM
vtec.dc2
Oct 13, 2002 06:07 AM
