Code 9?
Old May 13, 2004 | 05:10 PM
Forrest Gump 9's Avatar
Default Code 9?
Hey guys, I've just got a new code on my car. It's a LS/Vtec with B16 head and P28 ECU. The code is 9. The car still run fine. Bogging a little at the lower rpm but that's it. Code 9 is a cyclinder sensor. Where is this cyclinder sensor locate? Anyone has the same problem? Thanks!!
Old May 13, 2004 | 05:26 PM
ensracer's Avatar
are you sure its not the distributor?
Old May 13, 2004 | 06:04 PM
limpy's Avatar
Default Re: (eduardo)
I had a code 9 and it is the piston position sensor that is located in the dizzy. I was told that the only way to fix it was to replace the dizzy.
Old May 14, 2004 | 04:59 AM
JimBlake's Avatar
Default Re: (limpy)
If the wiring is loose, broken, open, shorted, or anything like that, you can find it & fix it. If the sensor itself is bad, I've heard you can't buy one unless you buy the whole distributor.
sebTeggy
Oct 21, 2011 09:28 PM
killafred187
Aug 12, 2011 05:15 PM
G0crxG0
Dec 3, 2006 02:38 PM
GuyInASpeedo
Sep 25, 2003 07:05 PM
RaIn
Apr 20, 2003 08:05 PM
