Gsr Manifold Sensors will B16 fit
Old May 13, 2004 | 03:48 PM
c8r9x's Avatar
Default Gsr Manifold Sensors will B16 fit
just like the topic says will the b16 manifold sensors fit a Gsr manifold?
Old May 13, 2004 | 04:47 PM
Rywire's Avatar
Default Re: Gsr Manifold Sensors will B16 fit (c8r9x)
Which ones? Ryan
Old May 13, 2004 | 05:00 PM
HamiltonRex's Avatar
Default Re: Gsr Manifold Sensors will B16 fit (droppedcrxsi)
yeah
theyll thread in. depending on the style of the sensor it might now work
-Eric
Old May 13, 2004 | 07:09 PM
c8r9x's Avatar
Default Re: Gsr Manifold Sensors will B16 fit (HamiltonRex)
any sensors that need to go onto the manifold tps, knock, etc.
Old May 13, 2004 | 07:34 PM
Rywire's Avatar
The tps is on the tb, but it will work. The knock is on the block, and will work too. They should all work. what others Are you swapping over, I can let ya know. Ryan
Old May 14, 2004 | 12:20 PM
c8r9x's Avatar
what sensors are on the gsr manifold, and which ones are on the b16
Old May 14, 2004 | 12:31 PM
Rywire's Avatar
The evac, and the little white one on the front thats attached by 2 screws (forgot the name), should bolt over. The gsr has the iacv on the TB, and the b16 has it on the IM, so I dont think it will work. Ryan
Old May 17, 2004 | 08:13 AM
c8r9x's Avatar
so i would need the gsr throttle body with the iavc but the tps sensor off the b16 will work
Old May 17, 2004 | 08:47 AM
Rywire's Avatar
Any tps from 88-00 civic, integra, exc.. works. Same part. Ryan
Hey, 2 gen b16s have the iacv on the tb too, pssibly others...
The gsr tb uses a different style "throttle cable spinner thingy", but they interchange with any b series.
So, wait, what are you trying to do exactly? Ryan
Mr.DC2TurBo
Mar 22, 2010 04:21 PM
kantfadedisazn
May 4, 2009 12:21 PM
sejthewedge
Apr 6, 2009 07:41 PM
pouponu
Dec 12, 2005 08:13 AM
canuck-mx6
Dec 27, 2001 11:49 AM
