rear lip install
Old May 13, 2004 | 01:57 PM
deviant1's Avatar
Default rear lip install
how do you mount a rear lip besides using the 2 screws on each end? mine came with long bolts and nuts. where would these go? i heard of people using bolts to hold on the center of the lip instead of using tape. any advice? pics?
Old May 13, 2004 | 02:14 PM
BANGBANG's Avatar
Default Re: rear lip install (deviant1)
for what ride?? civic?? if so, it happend to my homeboy too. we were like WTF?? so we said fudge it and just used double sided tape, 2 screws on each end and it worked fine.
Old May 13, 2004 | 02:28 PM
deviant1's Avatar
Default Re: rear lip install (BANGBANG)
it doesnt even fit now. it fit b4 i painted it. now its way to small for the rear bumper and wont even wrap around to the edges. sigh
Old May 13, 2004 | 06:25 PM
deviant1's Avatar
bump for trouble
Old May 13, 2004 | 06:30 PM
Ejay Six's Avatar
https://honda-tech.com/zerothread?id=864001
Have you enough threads? You fucked up your lip, it wont fit, boo ******* hoo, no one gives a ****.
Old May 13, 2004 | 07:45 PM
Civiclx's Avatar
Default Re: rear lip install (Ejay Six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ejay Six &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=864001
Have you enough threads? You fucked up your lip, it wont fit, boo ******* hoo, no one gives a ****.</TD></TR></TABLE>
wow asshat, way to help out someone in need, quit postwhoring btw, you have 700 posts since the new year, damn, to the thread started, two screws on each end, double sided tape
Old May 13, 2004 | 07:52 PM
Ejay Six's Avatar
Default Re: rear lip install (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">
wow asshat, way to help out someone in need, quit postwhoring btw, you have 700 posts since the new year, damn, to the thread started, two screws on each end, double sided tape </TD></TR></TABLE>
So much ******* help you were, 'asshat.'
He just said the lip wont fit around the sides, learn how to ******* read.
Old May 13, 2004 | 08:33 PM
deviant1's Avatar
thanks for the help and for those who didnt, oh wells. sorry to bother you.
Old May 13, 2004 | 10:12 PM
Civiclx's Avatar
He just said the lip wont fit around the sides, learn how to ******* read.</TD></TR></TABLE>
whoa whoa "*******" TWICE in one reply, I applaud your efforts to look like an "asshat" you succeed once again! Your mommy must be proud
As for the creator of the topic, I just learned how to "*******" read, its like the Type R of reading, and I understand the problem now. It seems as if the paint shrunk the abs or urethane a little bit, try heating it up with a heat gun if its plastic to get it more flexible. If its fiberglass I have no idea.
Old May 14, 2004 | 02:15 AM
deviant1's Avatar
the lip is plastic
Old May 19, 2005 | 12:50 PM
GUNNER666's Avatar
try screwing on side on and stretching the lip to make the other side fit?
did that with my buddies fron lip and it went on.\
good luck
tweek_boii
Apr 21, 2011 04:20 AM
NFC9225
Honda Civic (2001 - 2005)
Apr 4, 2011 09:13 AM
Shaguar47
May 12, 2010 05:27 AM
igo4bmx
Feb 8, 2005 09:05 AM
deviant1
May 16, 2004 07:40 PM
