Climate control lights not working?
On a EJ coupe, what should I check to find my problem if the climate lights are not working? The buttons light up if you push em, but not the part that is the indication area.
check your dimmer switch..it might be loose or disconnected...i know on eg's if you unplug the dimmer switch the climate control lights wont come on..the buttons will light up but the actual lights wont work..the guage cluster will still work fine also..i found this out when i installed my eg6 coinpocket...i just left my climate control the way it is cause at night it looks cool how only the guages are lit up
bromas203
Mar 14, 2014 05:18 PM
VtecCivic93
18
Jul 24, 2009 05:31 AM
JDM_EK_wanabe
Sep 28, 2006 02:03 PM
