throttle cuts out at full temp on B16A1
I have a 91 crx Si with a b16a1 motor and trans with full msd ignition and type R cams.
When my engine reaches full temp My air fuel mixture gauge runs totally lean as hell and then nothing happens when hit the gas. If I push in the clutch it works fine but not in gear at full temp. Car starts fine and drives great until it reaches full temp. NEED HELP! thanks!
How long were you driving for? Was it after the car would reach the warm up and allow VTEC to work?
I had nearly the same issue and the coil was to blame.
