sohc zc tranny
Old May 13, 2004 | 12:19 PM
underage's Avatar
Default sohc zc tranny
if i put this in a 91 civic i need to use 90-93 integra axles, right?
i tried to search but you can't search 'zc', so my results were somewhat limited.
Old May 13, 2004 | 01:09 PM
HumanResource's Avatar
Default Re: sohc zc tranny (underage)
Yup
same as the DOHC ZC trans
90-93 NON ABS (if it matters) Integ axles
Old May 13, 2004 | 01:41 PM
Colin's Avatar
Default Re: sohc zc tranny (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">
90-93 NON ABS (if it matters) Integ axles</TD></TR></TABLE>
abs and non abs are essentially the same. only difference is the abs axles have a ring around them that the abs sensors "sense" but size wise, and fitment wise... they're the same, so either should work.
Old May 13, 2004 | 02:02 PM
kyle h.'s Avatar
Default Re: sohc zc tranny (91IntegGS)
a wagon axle should work too
that is, if you want the half shaft system. but who wouldn't
Old May 13, 2004 | 03:29 PM
C-RICKS's Avatar
Default Re: sohc zc tranny (kyle h.)
So, you're saying that my axels myght not be the right ones?
Don't mean to hijack the post, but i have a SOHC zc engine on my 90 Si. The car still has the Si tranny, dist, flywheel,crank.
Theonly thing is, that no matter how much i adjust the clutch or whta not it seams as if tho my tranny and engine are not in sync.
Old May 13, 2004 | 03:50 PM
ZCdohcHB's Avatar
sohc zc tranny are the same as the usdm si tranny. so no u don't need to change ur axles. the dohc zc tranny is the one with the equal length axles which require the 90-93 integra axles and the zc intermediate shaft.
Old May 14, 2004 | 02:45 PM
Default Re: (ZCdohcHB)
SOHC ZC not the same as D16A6 trans
there is no JDM equiv to the "Si" USDM trans
I know they did off some trans that do not require the use of an intermediate shaft, BUT these are equiv to DX trans
Old May 14, 2004 | 02:49 PM
crxgator's Avatar
Default Re: (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">SOHC ZC not the same as D16A6 trans
I know they did off some trans that do not require the use of an intermediate shaft, BUT these are equiv to DX trans</TD></TR></TABLE>
what about the 1.5X, that has the same gearing and final drive as the USDM Si...
Old May 17, 2004 | 09:35 AM
Default Re: (crxgator)
what?
that's a new one for me?
got any pics?
Old May 17, 2004 | 09:41 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">what?
got any pics?</TD></TR></TABLE>
http://www.teamsdxracing.com/specs.htm
here is just one site, scroll all the way to the bottom...
Old May 17, 2004 | 09:47 AM
Hmmm look at that 4.25 indeed
I'm gonna hafta look again
I've checked (2) trannys off the carb'd SOHCs and both turned the same as the DX, but I'm gonna hafta focus more on the D15 carb'd engines
OOOtony
Mar 4, 2009 06:38 AM
hybrid1990crx
Jul 29, 2005 12:55 PM
neoclown2
May 10, 2005 07:30 PM
charjacq
Mar 2, 2003 09:21 AM
wronghand
Jan 17, 2003 05:56 AM
