weight loss
Old May 13, 2004 | 10:43 AM
splinter51's Avatar
Default weight loss
what are some things people have done to cut weight?
Old May 13, 2004 | 11:19 AM
Spooled1.6L's Avatar
Default Re: weight loss (splinter51)
atkins works pretty well if you like meats
Old May 13, 2004 | 11:26 AM
shoden's Avatar
Things that I've done personally:
Removed sunroof assembly, welded in steel plug (25-30lbs saved).
Swapped front bumper for an HF front bumper (weighs 1/3 to 1/2 less).
Swapped rear hatch for an HF hatch (no wiper assembly).
Relocated battery to rear and switched to a lighter sealed battery (20lbs saved?)
Swapped 3 spoke Si steering wheel for 2 spoke HF wheel (gotta be 3 or 4oz at least )
Future plans include:
Carbon fiber hood
Lightweight wheels (13" Panasports for autox, 15" Rotas for street)
Maybe switch to HF front anti-sway bar
Other options that I don't want to do:
Strip interior
Remove A/C
Lexan windows
Old May 13, 2004 | 11:36 AM
MooreBoost's Avatar
Default Re: weight loss (shoden)
I removed the A/C and stripped the interior.
Old May 13, 2004 | 01:35 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: weight loss (Spooled1.6L)
just watch your daily intake and when you eat.
Old May 13, 2004 | 01:42 PM
crxpilot's Avatar
removed spare tire and jack (keep a can of fix-a-flat in the car) ...about 40lbs
removed passenger seat ...about 45lbs including brackets
remove rear cargo covers and rug ...about 15lbs
12lb. wheels
Old May 13, 2004 | 01:51 PM
HamiltonRex's Avatar
Default Re: (crxpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpilot &raquo;</TD></TR><TR><TD CLASS="quote">removed spare tire and jack (keep a can of fix-a-flat in the car) ...about 40lbs
Since when does that crap fix a blown out tire.
Anyways, i took out my spare anyways.
Strip rear interior.
Remove A/C
Remove sunroof motor and assembly. CF plug
Removed Rear wiper and motor
Removed Fluid Resivoir for wipers
CF hood
Gutted bumpers
Removed tow hooks (not much there)
Removed all sound deating, under steats, on inside of firewall etc.
My list comes to an end.
-Eric
Old May 13, 2004 | 01:52 PM
USDM 4G VTEC's Avatar
if u dont need the heater where u live
by removing the heater core and **** like that under the dash saves a lot of weight
take pumpers off and cut some unnessesary metal material
if u have a 90-91 civic switch for 88-89 doors wich are lighter and have seatbelts inside car and avoid extra weight
Old May 13, 2004 | 02:11 PM
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">if u dont need the heater where u live
Sucks i live in canada eh
What do you mean by pumpers?
Old May 13, 2004 | 02:29 PM
Mr_CRX's Avatar
Default Re: (HamiltonRex)
I think he meant 'bumpers'.
Old May 13, 2004 | 02:39 PM
splinter51's Avatar
Default Re: (Mr_CRX)
some good stuff. already gutted interior of hb, no spare, no ac. i like the bumper idea. any more ideas. even little stuff counts
Old May 13, 2004 | 03:00 PM
APEX CRX's Avatar
Default Re: (splinter51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splinter51 &raquo;</TD></TR><TR><TD CLASS="quote">even little stuff counts</TD></TR></TABLE>
remove every other nut and bolt on entire vehicle. ha ha ok not that extreme. But if you look through the car there are some bolts that really aren't needed.
YOU DID SAY, EVEN STUFF COUNT
Old May 14, 2004 | 12:03 PM
LudeEFv2.4's Avatar
12lb. wheels</TD></TR></TABLE>
I keep a tire pulg kit and a small air compressor in my hatch. my brakes are too big for a spare anyway.
Old May 14, 2004 | 12:09 PM
SiRex91's Avatar
Default Re: (LudeEFv2.0)
Here's what I've done:
Cf hood
Completely stripped interior/Remove all sound deadening and insulation
Remove all a/c and heat (everything that goes along with it)
Remove stereo and speakers
Swapped out stock Si seats for some fixed back Momo's
Remove stock seat belts and retractors (replaced with Simpson 5pt harnesses)
Old May 14, 2004 | 04:21 PM
ketchup's Avatar
hahahha...atkins
has anyone mentioned polycarb windows yet ? that'll save you a good 50lbs. fiberglass hood/fenders ? good few lbs there..and if you really want to get jewish on cutting weight, replacing alot of the heavy nuts, bolts, skrews etc. with lighter ones will save you a bit.
Old May 14, 2004 | 04:23 PM
ketchup's Avatar
you can remove just the **** that heats instead of A/C althogether ? cuz i sure as HELL dont need heating in california.
f*ck why didn't i just use edit ?!
............your wind shield wipers and the motor
i don't think it's legal here in california to remove the seat belt set, someone will correct me if im wrong...
a good example of cutting weight would be to take a look at most of the cars at the track, nothing but a seat and a steering wheel.
Old May 14, 2004 | 06:31 PM
SECURITY's Avatar
Default Re: (ketchup)
some more:
HF doors are lighter
removing all of your wiper fluid (or the entire assembly) saves. every gallon = 8 lbs
also gas weighs ~8 lbs/gallon
It's not uncommon for people to have their hatches down to 1600 or 1700 lbs now.. cra-zee
Old May 14, 2004 | 06:40 PM
I3ackfire's Avatar
Default Re: (oh_crx)
RUST...
Old May 14, 2004 | 07:20 PM
Bunger's Avatar
Remove heat shielding, intake manifold bracket, any wiring you're not using (stereo, etc), lexan what you can, get some light seats and wheels.
I should have my CRX just under 1500lbs when I'm done. Last time I corner weighted it, it was sitting at 1775 and I've taken a good 150lbs out of it since then, and know I can take another 100lbs with seats (40lbs), wheels (25lbs), and CF hatch with lexan (35lbs).
Old May 15, 2004 | 10:25 AM
4DRmafia's Avatar
what part can i gut my bumpers from ?
Old May 15, 2004 | 11:23 AM
regime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spooled1.6L &raquo;</TD></TR><TR><TD CLASS="quote">atkins works pretty well if you like meats</TD></TR></TABLE>
lol
its true i lost 70 lbs on the atkins hahah ( no really i did)
Old May 15, 2004 | 12:19 PM
BAZ's Avatar
BAZ
Default Re: weight loss (ketchup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ketchup &raquo;</TD></TR><TR><TD CLASS="quote">hahahha...atkins
..and if you really want to get jewish </TD></TR></TABLE>
Whoah, watch what you say dude.
Old May 15, 2004 | 02:24 PM
ketchup's Avatar
Default Re: (civicsidude91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">
what part can i gut my bumpers from ?</TD></TR></TABLE>
the bumper bar (the big heavy metal bar behind your bumper cover). 10lbs
Old May 15, 2004 | 06:10 PM
4DRmafia's Avatar
ok then how can i keep my bumper without falling off since there no bumper metal <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ketchup &raquo;</TD></TR><TR><TD CLASS="quote">
the bumper bar (the big heavy metal bar behind your bumper cover). 10lbs</TD></TR></TABLE>bar
Old May 15, 2004 | 06:29 PM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">ok then how can i keep my bumper without falling off since there no bumper metal bar </TD></TR></TABLE>
Rear is easy, just remove it, and use the 2 screws on each side and some creative zip ties elsewhere, but be sure to use good ones... or else they break after a while. On an Si, this saves like 30lbs and you can't visually see the difference.
Now I know there are a large number of you out there that don't condone removing bumper supports, so I'm just going to say, be carefull everyone, don't get too crazy with weight reduction on a street car. Consider a tradeoff maybe, like strip 75 lbs and then add a nice 6 point cage or better, not only could it save your butt in a side impact, but it really makes the car feel and handle very solid!
