power vs weight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">With good driving/traction/suspension you could probably hit low 13's with about 2200 lbs and 180 whp.</TD></TR></TABLE>
i'd say 170ish..
i'd say 170ish..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">
i'd say 170ish..</TD></TR></TABLE>
i'd be willing to drop to 160-165. suspension and tires are your main issue. if you cannot get the power to the ground, it is worthless.
agreed
agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeEFv2.0 »</TD></TR><TR><TD CLASS="quote">
i'd be willing to drop to 160-165. suspension and tires are your main issue. if you cannot get the power to the ground, it is worthless.</TD></TR></TABLE>
you'd probably hav eto start getting into the 1.7 60fts or better at 160-165 2200lbs..
depends on soo omany things though.. so it's almost not worth discussing
depends on soo omany things though.. so it's almost not worth discussing</TD></TR></TABLE>
very true. altitude, air temp, densidy, track conditions, ect, ect.
very true. altitude, air temp, densidy, track conditions, ect, ect.</TD></TR></TABLE>
Altitude makes a very big difference in n/a cars.
1800lbs, with you in it.
150whp+
and decent gearing.
Play with this
it'll give you an IDEA (not factual) of what is needed.
edit: around 12lbs per HP should do the trick.
150whp+
and decent gearing.
Play with this
thanks guys.....i know there is alot to take into consideration.....lets face i just want my hatch to be faster then that mustang that pulls up next to me with some white trash mullet driving it....(lot of them around here)
anyone have any #s or timeslips to prove this? im not doubting it at all. and is this on street tires or slicks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 »</TD></TR><TR><TD CLASS="quote">
anyone have any #s or timeslips to prove this? im not doubting it at all. and is this on street tires or slicks?</TD></TR></TABLE>
i ran 13.1 with a ZC on ZEX... it doesn't take a crazy amout of WHP in an EF to tap the 13's.
i saw some guy in a hatch back with an itr i/e/h run mid 12s on slicks. So you figure that he was pushing what 180 or 190 whp? I'm know im guess but either way i figured 170 should net you 13s pretty easy.
DEF
DEF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron »</TD></TR><TR><TD CLASS="quote">Hmm that thing isn't even close
it gave me 17.1
on a 2400 lb car. with 110(generous for a 180k stock si) flywheel hp
I ran a 15.9</TD></TR></TABLE>
first, have your car weighed with you in it.
then, get your car dynoed.
finally, compare it to the link i posted.
You can't estimate your curb weight with you in the car, then estimate how much HP you make and expect it to be even close.
For me, at a race, my car weighed at 2264lb with me in it and it made 134whp.
my best run was a 14.80 at that weight. the link says 14.90. Pretty close.
it gave me 17.1
OK... here is what I'm sayin
curb weight for my car is like 2300 or somethin... so i put 2400
I'm probably making 80 whp with my stock D16A6 with 180k miles on it
i gave myself the benefit of the doubt and gave myself 30 extra hp
and the time was still over a second slower then I ran.
it's way off. i could dyno the car and weigh it and I'll get similar numbers and put them in... it'll still tell me that i run 17.1
maybe it works for other cars but not for mine... who can argue with the numbers i put in... the hp was generous and it still gave me a slow time
sry to be a dick or whatever... i was just sayin it didn't work for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eresuncabron »</TD></TR><TR><TD CLASS="quote">OK... here is what I'm sayin
sry to be a dick or whatever... i was just sayin it didn't work for me</TD></TR></TABLE>
From what ive read most A6s dyno around 100whp regardless of the amount of miles on them
a JDM type R will do it for sure OR Maybe SIR GSR 185hp might with few bolts ons
if your car is stock suspension I think it should be able to handle it but I don't know I only had a 185hp stock b16a.
I don't know about the torque factor
