d16y8 exhaust manifold on crx si?
Old May 13, 2004 | 09:37 AM
crxgator's Avatar
Default d16y8 exhaust manifold on crx si?
i was givin a d16y8 exhaust manifold yestarday...i was wondering if anyone used it on their crx? would it bolt-up, i know you have to move the o2 sensor, but thats not a big deal...
Old May 13, 2004 | 09:41 AM
EL Vap133's Avatar
Default Re: d16y8 exhaust manifold on crx si? (crxgator)
I don't see why it wouldn't. D-series and D-series.
90SICRX's Avatar
well i haven't done it but the best bet would be to hold it up and see if the holes match up..arn't most exhuast manifolds the same d wise? except maybe the ZC which IS diffrent.
Old May 13, 2004 | 09:42 AM
crxgator's Avatar
Default Re: d16y8 exhaust manifold on crx si? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I don't see why it wouldn't. D-series and D-series. </TD></TR></TABLE>
i know that, but i mean as far as length of the exhaust manifold and where the oil dipstick on the a6 is between the manifold where-as on the y8 its on the side of the engine...if that would hit...the mounting holes are the same i know that...
Old May 13, 2004 | 09:45 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
i know that, but i mean as far as length of the exhaust manifold and where the oil dipstick on the a6 is between the manifold where-as on the y8 its on the side of the engine...if that would hit...the mounting holes are the same i know that...</TD></TR></TABLE>
Customize it. Instead of posting it here, go outside and slap it on, not that hard.
Old May 13, 2004 | 05:35 PM
crxgator's Avatar
bump...
Old May 23, 2004 | 09:24 AM
crxgator's Avatar
installed, simple swap out, no modding needed...
Old May 24, 2004 | 12:48 AM
7PSI CRX's Avatar
Way to go Gator.
Lemme see a pic!
Old May 24, 2004 | 05:57 AM
phatrick2332's Avatar
you got good clearance on the pan now? I put a z6 exhaust mani on my b1 and it eventually wore a hole in the stock pan, swapped to a z6 and ran it till i just had a 2.5 inch downpipe
Old May 24, 2004 | 06:40 AM
crxgator's Avatar
Default Re: (phatrick2332)
here are some pics
Old May 25, 2004 | 01:08 PM
7PSI CRX's Avatar
Default Re: (crxgator)
Ha Ha.
Beautiful!
Now you've gotta cut off those heat shroud brackets.....
They're fugly.
Old May 25, 2004 | 01:59 PM
4drEF's Avatar
Keyboard Humorist
Nice job! Poorman's OEM header.
You even got the "money" shot underneath the car. Do you notice if you have more clearance underneath the oil pan to the motor now?
91 CRX Si-Tahitian Green.... and a rustaaayyy Da16Y8 exhaust manifold.
Old May 25, 2004 | 02:19 PM
JCracer723's Avatar
Default Re: (4drEF)
woot? i didnt thats how the Y8 mani looked like
Old May 25, 2004 | 02:27 PM
-16V-'s Avatar
Default Re: (JCracer723)
Any performance gains???
Old May 30, 2004 | 05:37 PM
crxgator's Avatar
Default Re: (-16V-)
ehh maybe a tiny bit...i notice my exhaust is a lot louder now...
Old May 30, 2004 | 05:38 PM
crxgator's Avatar
yeah its a 4-2-1...
a lot better than the a6/z6/zc...
Nolan.EF
May 3, 2019 11:53 AM
jdmcivicracer89
Apr 28, 2010 08:53 AM
byronl
Jul 6, 2006 07:08 PM
wolfriley
11
Mar 19, 2004 01:27 PM
