HELP needed for GSR front brake swap parts list on 92 Si Hatch (4 wheel disc)
Old May 13, 2004 | 08:17 AM
92BlackSi's Avatar
Default HELP needed for GSR front brake swap parts list on 92 Si Hatch (4 wheel disc)
I have been searching the forums and have come across tonnes of varying information about brake swaps, MC, BB etc...
I need new front rotors on my car and would like to get some increased braking performance while I am at it. My car has 4 wheel disc brakes. I have the following info so far:
Can swap in a 1991 Civic EX 4 door MC Part No. 46100-SH4-A11
GSR rotors
GSR calipers?
That way will require less work and no line bending or flaring?
OR
Integra 94 LS/RS and up MC
Teg brake booster
GSR rotors
GSR calipers?
I would prefer the first way but which way is better and do I need the GSR calipers? I DO NOT WANT TO DO ANY BRAKE LINE WORK.
Thanks
Old May 13, 2004 | 08:27 AM
92BlackSi's Avatar
OK I am also seeing that an 88-89 Integra MC is the same as the 91 Civic Ex 4 door one?
AND Ls calipers are the same as GSR calipers.
Am I better off upgrading to the GSR front suspension? Like GSR knuckles? Do knuclkes include everything needed?
Old May 13, 2004 | 08:50 AM
ABK's Avatar
ABK
Default Re: (92BlackSi)
you don't need the MC, my friends cx with SIRII brakes stops like crazy with his stock MC. It actually gives it a better brake feel.
And yes you will need knucles. You can use GSR, ABS SI/EX, or SIRII brakes for the upgrade. After that you will need aligment and camber kit if you don't already have it because my friend's camber jumped after the swap.
nickelz34
Aug 22, 2013 05:07 PM
Infamous_Imports
Oct 7, 2004 01:45 PM
BeerMan
Dec 15, 2002 08:43 PM
TurboBumblBee
20
Jan 30, 2002 05:06 AM
