Steering Column Removal...EG
Old May 13, 2004 | 07:33 AM
3.3.3's Avatar
Default Steering Column Removal...EG
alright. i need to swap out my steering column since my lock is broken off.
my question is, how do i keep the alignment? after i remove the steering wheel and put the new column in, will it steer fine?
hope this makes sense.
Old May 13, 2004 | 09:51 AM
Ekasey's Avatar
Default Re: Steering Column Removal...EG (3 3 3)
the steering column shouldn't affect your alignment just make sure you position the wheel straight ahead when the tires are straight ahead
Old May 14, 2004 | 09:49 AM
3.3.3's Avatar
Default Re: Steering Column Removal...EG (eLusive ek4)
thanks a lot
Old May 14, 2004 | 12:53 PM
doublejz's Avatar
be sure not to let the steering wheel spin when you disconnect the steering column from the rack. If it spins it'll break your cable reel for srs which will kill your horn, srs, cruise control. Pull the steering wheel off first and remove the cable reel just to be safe.
-Speaking from experience
rhoptry
Apr 28, 2013 07:10 PM
huckaboo
Suspension & Brakes
Apr 7, 2009 02:20 PM
breanna
Feb 28, 2006 12:51 AM
incognito21
Acura TL, RL & ZDX
Feb 23, 2005 09:20 AM
choi830
Oct 30, 2003 05:13 AM
