Intake pressure for a d16z6
Old May 13, 2004 | 05:03 AM
DjFreeze's Avatar
Default Intake pressure for a d16z6
whats a normal IP for a d16z6 with i/h/e/tb/vafc
Old May 13, 2004 | 09:58 AM
Ekasey's Avatar
Default Re: Intake pressure for a d16z6 (DjFreeze)
intake pressure? i think you are reffering to vacuum and rouhgly between 20 - 16 in/hg
Old May 13, 2004 | 02:26 PM
500hpsi's Avatar
Default Re: Intake pressure for a d16z6 (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote"> between 20 - 16 in/hg</TD></TR></TABLE>
anything below 18 is not normal. U want to see between 21-18 at idle and at 2500 rpm about 28-23 inches of vac.
Old May 13, 2004 | 04:30 PM
dfoxengr's Avatar
Default Re: Intake pressure for a d16z6 (500hpsi)
intake pressure hmm. it all depends on throttle position,. if you even mean vacuum.
Old May 13, 2004 | 04:42 PM
Ekasey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 500hpsi &raquo;</TD></TR><TR><TD CLASS="quote">
so a motor with a large large cam running 15 in/hg vacuum wouldn't be normal i think you should research more and regardless what if he is at WOT at 2500 RPM seeing any vacuum would not be normal
Old May 15, 2004 | 06:46 AM
crxsirvtec's Avatar
NEVER BUY FOR THIS GUY VERY VERY VERY VERY VERY VERY BAD SELLER!!!!
anyone live in the new jersey area, want to go beat his ***??
Old May 18, 2004 | 09:03 AM
spark plugs.
Guest
Posts: n/a
Default Re: Intake pressure for a d16z6 (crxsirvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsirvtec &raquo;</TD></TR><TR><TD CLASS="quote">NEVER BUY FOR THIS GUY VERY VERY VERY VERY VERY VERY BAD SELLER!!!!
why don't you save that for another thread?
so a motor with a large large cam running 15 in/hg vacuum wouldn't be normal i think you should research more and regardless what if he is at WOT at 2500 RPM seeing any vacuum would not be normal </TD></TR></TABLE>
you shouldn't see vacuum at WOT. i.m. vacuum and atmosphere are now at balance b/c of straight air flow.
silentdaredevil2
Jun 2, 2007 01:04 PM
komat
Jan 22, 2005 04:38 PM
spark plugs.
May 18, 2004 07:47 PM
TOFU.man
May 1, 2004 07:04 AM
94dxt
Apr 20, 2003 07:14 PM
