B16 into DA... swap questions.
Old May 13, 2004 | 04:45 AM
lsvtec_DA's Avatar
Default B16 into DA... swap questions.
I am getting ready to help a friend install a B16 into his DA.
What upper rad hose can I use for this application? The 94+ integra? 92-93 gsr? del sol??
Is there anything else that I should be aware of or look out for before begining the swap?
thanks
Old May 13, 2004 | 04:59 AM
4crx4me's Avatar
Default Re: B16 into DA... swap questions. (lsvtec_DA)
I would say if the rad is stock a '92-'93 GS-R hose. A B17 is basically a stroked B16, anyway. So th hoses should be the same for both.
Old May 13, 2004 | 08:14 AM
nickgmiller04's Avatar
Default Re: B16 into DA... swap questions. (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">I would say if the rad is stock a '92-'93 GS-R hose. A B17 is basically a stroked B16, anyway. So th hoses should be the same for both. </TD></TR></TABLE>
correct on the g2 gsr hose. visit http://www.g2ic.com and look at the engine swap guide. theres actually a b16 swap thats separate from the regular engine swap. that site will answer any and every question you have about a b16 into a DA
Old May 13, 2004 | 08:19 AM
G
sh!t happens.
Default Re: B16 into DA... swap questions. (nickgmiller04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickgmiller04 &raquo;</TD></TR><TR><TD CLASS="quote">
correct on the g2 gsr hose. visit http://www.g2ic.com and look at the engine swap guide. theres actually a b16 swap thats separate from the regular engine swap. that site will answer any and every question you have about a b16 into a DA</TD></TR></TABLE>
91crx-si
Oct 22, 2008 05:53 PM
civictech01
Oct 19, 2005 07:28 PM
ls-t del sol
Oct 7, 2002 12:31 AM
