help: thump when braking or accelerating harder than normal
Old May 13, 2004 | 12:15 AM
slimbo's Avatar
Default help: thump when braking or accelerating harder than normal
this happens much more noticably in the wet, although i can provoke the noise in the dry if i do a full emergency stop.
basically, if i brake hard enough i hear this thump from the front end of the car, the next time i accelerate hard i'll hear the same thump again. it's quite strange...
could it be an engine mount?
Old May 13, 2004 | 12:31 AM
riceball777's Avatar
Default Re: help: thump when braking or accelerating harder than normal (slimbo)
bump for answers
i have the same problem but only when i come to a stop.
it makes 1 thump right before i'm almost at a stop
to me it sounds like an axel but i dont know
Old May 13, 2004 | 01:13 AM
Kusai.Nihonjin.Desu's Avatar
Default Re: help: thump when braking or accelerating harder than normal (riceball777)
Suspension? And double checking mounts shouldnt be that hard.
Old May 13, 2004 | 01:53 AM
Slow_Em1's Avatar
Default Re: help: thump when braking or accelerating harder than normal (Nihonjin)
check your LCA's
Old May 13, 2004 | 01:55 AM
slimbo's Avatar
Default Re: help: thump when braking or accelerating harder than normal (Slow_Em1)
i've checked all the suspension joints, they apear to be okay...
also, why is it that it occurs most noticably in wet weather??
Old May 13, 2004 | 03:19 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slimbo &raquo;</TD></TR><TR><TD CLASS="quote">i've checked all the suspension joints, they apear to be okay...
wow that woulda been my best bet. wheel bearing?..take the wheel off and if you can shake that thang 'round like a lasso then its yer whel bearing. heh
keep us posted y0
Old May 13, 2004 | 03:45 PM
95lsvteg's Avatar
i just had the same problem. it's a real anoying noise. i changed my rotors and pads. worked fine.. check your rotors. i didn't think it would have been them and it turned out it was.
Old May 13, 2004 | 05:07 PM
Cramerox's Avatar
wheel bearings dont sound like that...
Old May 13, 2004 | 05:18 PM
NelsitoTeg's Avatar
Could it be that your caliper is about to go?
Old May 13, 2004 | 05:41 PM
Space Boy's Avatar
Default Re: help: thump when braking or accelerating harder than normal (NelsitoTeg)
If you are not sure then bring it to a mechanic.
Besides that I also had a thump like your describing and it turned out to be a front ball joint. cost 200$ to fix and the car was golden again!
Old May 13, 2004 | 05:50 PM
Keno20's Avatar
Definitly sounds like it could be an engine mount. I'd check them out before I started pulling things apart.
Old May 13, 2004 | 05:56 PM
Cramerox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NelsitoTeg &raquo;</TD></TR><TR><TD CLASS="quote">Could it be that your caliper is about to go?</TD></TR></TABLE> I didnt know that was possible....maybe its your mufler bearings...
Old May 13, 2004 | 07:20 PM
slimbo's Avatar
Default Re: help: thump when braking or accelerating harder than normal (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote"> I didnt know that was possible....maybe its your mufler bearings...</TD></TR></TABLE>
nah, not possible, i had them re alligned last wednesday.
seriously though, ball joint is a good suggestion. i have no idea how to test that part out though, any write-ups?
is that the sort of thing that will go clunk in wet weather?
Old May 13, 2004 | 09:28 PM
mugenracer's Avatar
Motor mount?
Old Nov 7, 2004 | 09:04 PM
Toadfart's Avatar
Back from dead. I get a slight thump when close to coming to a complete stop. And also when my wheel is turned completely to one side.
Bump!
bk7794
May 26, 2012 02:59 PM
aalb1
16
May 18, 2006 03:39 PM
pos_cd5
May 8, 2006 03:40 PM
mikehawkBUiLT
Suspension & Brakes
13
Jun 29, 2005 11:15 PM
