ACT clutch pedal feeling lighter than usual....
Old May 12, 2004 | 09:20 PM
Simple's Avatar
Default ACT clutch pedal feeling lighter than usual....
So i fill my clutch fluid res. (was still 95% full anways) and now my clutch pedal seems to be feeling lighter than usual.
could it be the tension on the spring on the pedal for some reason?
new fluid introduced?
clutch shitting out on me....
i dont think its the clutch shitting out. It still grabs every time, even on the hard shifts. can still hear the squeek of the ACT when it grabs just like normal....
im clueless, and i dont like it
Old Jul 27, 2004 | 09:42 PM
sPaRk'iT's Avatar
Default Re: ACT clutch pedal feeling lighter than usual.... (Simple)
i would like to know too, samething as mine.
Old Jul 27, 2004 | 09:53 PM
BluePrintmfg.com's Avatar
Banned
try bleeding the clutch line, might have some air in the line. Hope that works
Old Jul 28, 2004 | 05:15 PM
Porter Racing
Guest
Posts: n/a
Default Re: ACT clutch pedal feeling lighter than usual.... (11sec.ALL MOTOR)
Your perssure plate might have taking a ****. ACT has problems with their diaphrams breaking If that is the case you need a new clutch and take a look at this web site for a new clutch, http://www.TurboClutch.com.
Old Jul 28, 2004 | 07:51 PM
-faded-'s Avatar
Default Re: ACT clutch pedal feeling lighter than usual.... (Porter Racing)
also it could be the slave cylinder
Old Jul 28, 2004 | 09:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: ACT clutch pedal feeling lighter than usual.... (hybridlsR)
mines doing the same thing after i bled the clutch after a tranny change , im thinking i got some air in there.
i have an act clutch as well
Old Sep 17, 2004 | 11:16 PM
blkgsr03's Avatar
i have same problem, i changed the fluid and it still the same, the pedal is not a hard as before, and it doesnt grab hard at alll, do i need a new clutch?
Simple
May 15, 2004 12:17 PM
PetroGuyX
Jun 21, 2003 06:24 PM
Steve
Jul 23, 2001 01:42 PM
