B18B1 into 88 crx si??? searched but every one go somethin different to say!
Old May 12, 2004 | 08:12 PM
1SickHb's Avatar
Default B18B1 into 88 crx si??? searched but every one go somethin different to say!
My Boy Has an (b18b1) 96 ls engine, tranny ,and axels(motor is complete, harness is still on it, intake manny headers....blah blah)
he wants 600$ and the engine has 60,000 miles........
Now my question is wat else and wat to i need to drop this into my 88 crx si!
yes ive searched! But some people say this and some people say that! this thread is for people who actually pulled this off!........im willing to buy it but i need to kno was up wit the wiring < thats wat i dont wanna deal wit...... thanks..
Rob.
ps. he got the gsr head.....he wants 800 for everthing so i just might make the rex ls/vtec but i really need the info !! thanks!
Old May 12, 2004 | 10:00 PM
civickiller's Avatar
Default Re: B18B1 into 88 crx si??? searched but every one go somethin different to say! (si Rob)
why dont you tell us what some people said that conflicted with each other
Old May 12, 2004 | 10:03 PM
0554's Avatar
i was going to answer your post but got too lazy haha. well i will give you the wiring. use your stock harness and either rewire the ls distributor or use your stock one. ah **** it i am this far might as well tell you the rest. get HASPORT MOUNTS. or another shitty brand but i prefer hasport. you need a cable tranni or just get the hasport cable to hydro conversion. and shift linkage you can either buy premade ones or modify your stock ones.
Old May 13, 2004 | 04:14 AM
crx_88_si's Avatar
Default Re: (88crex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex &raquo;</TD></TR><TR><TD CLASS="quote">i was going to answer your post but got too lazy haha. well i will give you the wiring. use your stock harness and either rewire the ls distributor or use your stock one. ah **** it i am this far might as well tell you the rest. get HASPORT MOUNTS. or another shitty brand but i prefer hasport. you need a cable tranni or just get the hasport cable to hydro conversion. and shift linkage you can either buy premade ones or modify your stock ones.</TD></TR></TABLE>
just to clarify some of his info..
you cant use your stock distributor. You need to get a 90-91 Teg LS Dist. that will bolt straight to the engine , and then plug right into your harness.
you can either get the hasport linkage (also made by other companies) or you can modify a TEG linkage to fit, not your stock one. You will also need misc pieces like hoses and cables (throttle/clutch)
Old May 13, 2004 | 04:52 AM
1SickHb's Avatar
Default Re: (crx_88_si)
cool thanks!
Old May 13, 2004 | 05:22 AM
4crx4me's Avatar
The first thing you need to do is decide if you're going to downgrade the engine to OBD0 Or upgrade the car to OBD1. OBD1 is the better choice BTW. You can't DO anything until you decide THAT. That will tell you which direction to go in. But you will need a cable tranny that's for sure.
HTH
Old May 13, 2004 | 05:23 AM
Default Re: (si Rob)
you gotta use your stock injectors and resistor box on the b18b motor if you decide to go to obd0 since its low impedance injectors, then you also need a obd0 ecu, if you use the obd0 teg dist.
what happen to taht 90-91 teg engine you pmed me about ?
Old May 13, 2004 | 07:12 AM
1SickHb's Avatar
Default Re: B18B1 into 88 crx si??? searched but every one go somethin different to say! (4crx4me)
ima stay obdo
Old May 13, 2004 | 07:22 AM
crx_88_si's Avatar
go buy a 90-91 teg LS Dist. use your obd0 (88crxsi) Injectors. 90-91 pr4 ECU. Hydro conversion kit, hasport mounts and linkage and bingo
Old May 13, 2004 | 05:28 PM
0554's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
you can either get the hasport linkage (also made by other companies) or you can modify a TEG linkage to fit, not your stock one. You will also need misc pieces like hoses and cables (throttle/clutch)</TD></TR></TABLE>
oh really you cant modify your stock one's? damn my crx must have came with ls ones then becuase i modified the stock ones. lol. anything is possible with a welder. granted it is easiar to modify the ls ones. it can be done with your stock ones. and as for the distributor. you might be right but i thought my buddy used his stock hf distributor when he did his ls swap. i donno though. anyways thanks for clearin that up.
Old May 13, 2004 | 05:37 PM
ThatRicerDaniel's Avatar
you'll need a tranny .. the 96 is hydro and you need a cable tranny.
Old May 13, 2004 | 07:01 PM
yellowCRX6's Avatar
Default Re: (NitrousDreamz)
88 crx si said it all - go buy a 90-91 teg LS Dist. use your obd0 (88crxsi) Injectors. 90-91 pr4 ECU. Hydro conversion kit, hasport mounts and linkage and bingo
i just did the swap, and its not bad at all. u have to extend the map wires off the firewall and i think extend one plug. sell your hydro tranny and get a cable one, itll be easier. youll have to mess with the throttle cable as well. i had a special bracket from jdmshit.com that worked awesome.
Old May 13, 2004 | 07:06 PM
I Want An Si's Avatar
WRONG...... you can use your stock dizzy it will only bolt up with one bolt though
Old May 13, 2004 | 11:03 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si Rob &raquo;</TD></TR><TR><TD CLASS="quote">ima stay obdo</TD></TR></TABLE>
By downgrading the engine to OBD0, you do reliase that you are sacrificing something like 10-15 Hp
OBD0 B18A1=130-135Hp
OBD1 B18B1=140-145Hp
Just my .02 cents.
JWhonda_ride
Mar 25, 2008 11:40 AM
93dagsr
Dec 13, 2007 06:50 AM
perseverance
Mar 3, 2007 03:26 AM
ransack
30
May 10, 2004 06:39 PM
Jules Winnfield
Apr 6, 2004 08:42 PM
