fuel pump question?
Old May 12, 2004 | 07:42 PM
Todapwr's Avatar
Default fuel pump question?
I plan to run 8lbs of boost on my b16 soon and i wanted to know if a walbro 195 will do the job or do i need the bigger 255?
Old May 12, 2004 | 07:44 PM
zseeanz's Avatar
Default Re: fuel pump question? (TodaPwr)
your stock pump would be fine, but I'd get the 255 cause down the road, you'll probably wanna turn up the boost
Old May 12, 2004 | 07:51 PM
Miracle Swap16's Avatar
you can't just upgrade your pump without upgrading the regulator, fuel rail and injectors. Even if you get a pump and turn up the fuel pressure with an adjustable regulator, it will cause the injectors to drip, not spray. The key to good combustion is good atomization of fuel. You should also probably get the 255 lph pump after you have upgraded the rest of your fuel system so that your pump would be able to put out good fuel pressure without making the pump work at maximum load. The stock pump would probably crap out on you if it worked to hard for too long.
dome
Sep 25, 2007 02:50 PM
si0385.
Jan 14, 2006 11:51 AM
86si
Jan 31, 2005 07:18 PM
Screamer
Jun 18, 2003 09:17 AM
