HELP!!!!!!!!!!Taillights are not working!!!!!!!!!!!!!!!!!!!!!!!
Old May 12, 2004 | 07:24 PM
NiceDc2r's Avatar
Default HELP!!!!!!!!!!Taillights are not working!!!!!!!!!!!!!!!!!!!!!!!
Just got the car out of the shop.....got the jdm front end....later on that night i noticed my running lights in the taillights were not working.....checked the fuses and the two fuses for the running lights are missing....replaced the fuses still no running lights and now my brake lights dont work...all the fuses are fine, all bulbs are fine...please help!
taillights arent working
brake lights arent working
rear turn signals work
reverse lights work
bulbs are good
fuses are good
please help
Old May 12, 2004 | 07:47 PM
boostn420's Avatar
Default Re: HELP!!!!!!!!!!Taillights are not working!!!!!!!!!!!!!!!!!!!!!!! (NiceDc2r)
I say check the grounds for those lights. Both lights are on the same bulb, so the ground is common for both.
Old May 12, 2004 | 10:58 PM
NiceDc2r's Avatar
Default Re: HELP!!!!!!!!!!Taillights are not working!!!!!!!!!!!!!!!!!!!!!!! (boostn420)
were is is grounded...
Old May 12, 2004 | 11:42 PM
Reason's Avatar
I would take it back to the shop. Just my opinion.
Old May 13, 2004 | 03:17 AM
vtecsinan's Avatar
maybe the problem is the fusebox...
i had to replace with a new one had the same problem as yours... checked all the fuses all fine... they said that its the fusebox... i took it out from a wrecked civic it works fine now...
Old May 13, 2004 | 07:35 PM
jeremy.'s Avatar
Default Re: HELP!!!!!!!!!!Taillights are not working!!!!!!!!!!!!!!!!!!!!!!! (vtecsinan)
up
Old May 13, 2004 | 09:42 PM
Redline130's Avatar
I assume you checked the fuse in the fuse box that is under the hood as well? I had a similar problem....after tracing all the wires back from the tail lights, turned out it was the fuse in the fuse box that's in the engine bay. I think it's labeled STOP.
KingKongCanada
Jan 5, 2009 07:00 PM
jdm93cx
Honda S2000
Dec 17, 2005 08:41 PM
chickenandpickles
Apr 25, 2005 05:20 AM
dturbo
Mar 22, 2005 02:57 PM
NiceDc2r
May 13, 2004 10:56 PM
