Taillights are not working!!!
Just got the car out of the shop.....got the jdm front end....later on that night i noticed my running lights in the taillights were not working.....checked the fuses and the two fuses for the running lights are missing....replaced the fuses still no running lights and now my brake lights dont work...all the fuses are fine, all bulbs are fine...please help!
taillights arent working
brake lights arent working
rear turn signals work
reverse lights work
bulbs are good
fuses are good
please help
reverse lights work
bulbs are good
fuses are good
please help
what kind of running lights are u using? if u use the jdm city lights, they will burn out the fuses quickly. if this is happening, i used the USDM parking lights in place of the jdm city lights (and replaced fuses if nessesary) and no problems since..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Since you just got the car out of the shop I suggest you bring it back in and tell them to fix what they messed up.</TD></TR></TABLE>
It could be your brake light switch underneath the brake pedal.
Because a similar incident happened to my friend. None of his brake lights and rear running lights weren't working. After checking all the fuses and looking at his Helms manual, his last resort was the switch. Once he replaced that switch, his tail lights were fully operational.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiceDc2r »</TD></TR><TR><TD CLASS="quote">ITS THE TAILLIGHTS NOT THE HEADLIGHTS</TD></TR></TABLE>
the brake light and the running light are the same fuse
sweux
Aug 5, 2017 06:02 AM
NiceDc2r
May 13, 2004 09:42 PM
