Diameter of rear trailing arm bushing on 90/91 CRX Si?
Old May 12, 2004 | 07:16 PM
Wes V's Avatar
Default Diameter of rear trailing arm bushing on 90/91 CRX Si?
In order to end a discussion on the G2IC board, I need to have somebody measure the outside diameter of the rear trailing arm bushing.
This has to be taken from an ORIGINAL 1990 or 1991 CRX Si and the car should have rear disk brakes.
I'm talking about the outside of the bushing shell and it would be best if you can measure it with a vernier caliper. You don't have to remove the arm, just put it up on jack stands.
Wes Vann
Old May 13, 2004 | 02:46 PM
Wes V's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (Wes V)
Bump
Old May 13, 2004 | 02:55 PM
EL Vap133's Avatar
Someone help this guy. My car is at home and I'm at work or else I'd help.
Old May 13, 2004 | 02:57 PM
APEX CRX's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Someone help this guy. My car is at home and I'm at work or else I'd help. </TD></TR></TABLE>
same here, if no one posts up. I will later tonight
Old May 13, 2004 | 04:27 PM
crxgator's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (APEX CRX)
so you know they are smaller than the integra ones...they work without using the extra sleeve unlike the integra...i believe its 80.1mm that keith messured on the mugen ones which are the same as the oem honda...
Old May 14, 2004 | 03:57 AM
Arvid's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">so you know they are smaller than the integra ones...they work without using the extra sleeve unlike the integra...i believe its 80.1mm that keith messured on the mugen ones which are the same as the oem honda...</TD></TR></TABLE>
I had the parts guy at my Honda dealer measure one they had in stock. It was about 80 mm in diameter.
Old May 14, 2004 | 05:21 AM
crxgator's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (Arvid)
my memory is awesome...
Old May 14, 2004 | 06:09 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">my memory is awesome... </TD></TR></TABLE>
I believe I said 80.5mm.
Old May 14, 2004 | 06:18 AM
crxgator's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (keithv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv &raquo;</TD></TR><TR><TD CLASS="quote">
I believe I said 80.5mm. </TD></TR></TABLE>
i think you need to remeasure that, im always right...
Old May 14, 2004 | 07:39 AM
Wes V's Avatar
I hate to be "snippy", but I need the measurement taken off of a car that has the original arms and disk brakes. Not what a dealer says is the correct bushing.
The reason is that I'm trying to confirm if the original design uses the "large" diameter Integra bushings or "small" diameter design used on all other fourth generation Civics.
Other than the service bulletin that was released in regards to "Civic" bushings there isn't any dealer cross-reference to the trailing arm bushing, so there may be a mis-understanding (or confusion) at the dealers.
This comes up due to my picking up from a knowledgable Honda junk yard a trailing arm (for a rear disk brake conversion) that was supposedly from a CRX Si. It had the large diameter bushing.
As a result, I was going on the assumption that all of the disk brake arms use the large diameter bushings.
I'm just trying to find out what is reality.
Wes Vann
Old May 14, 2004 | 09:01 AM
crxgator's Avatar
ok, my car is a 91 crx si with the rear disc, i used the bushing you buy from honda that works on all 88-00 civics, no problem with the install, just pressed in it and went with my business...it is smaller than the integra...
Old May 14, 2004 | 09:19 AM
XrcR6's Avatar
Just adding...
I checked before I left for work this morning. The original stock rear trailing arm bushing I had removed from my '91 CRX-Si was ~80.5mm O.D. like previously mentioned.
Old May 14, 2004 | 10:52 AM
Wes V's Avatar
Default Re: Diameter of rear trailing arm bushing on 90/91 CRX Si? (XrcR6)
Thanks to all!!
Wes
wickedEFguy
Jun 23, 2009 03:07 PM
redwards
10
Jan 25, 2007 06:35 PM
thrill91si
Aug 20, 2003 03:02 PM
cd1fidy
Apr 10, 2003 12:34 PM
Fishcat37
11
Apr 9, 2003 11:16 PM
