need help with starter and flywheel!!
I have a 98 r, it has a Jun lightweight flywheel on it. Every now and again when i try to start it the starter grinds and makes a horrible noise. When i called Jun the people said that the flywheel is made for the jdm spec itr's. They said on the jdm itr's the teeth on the starter are a little diffrent. Of course they didnt mention that when i bought it, anyone have any advice on how to fix that???
You can change the starter, change the flywheel, or try to ignore the occasional grinding.
Actually, I seem to recall a long while back that someone had filed or somehow modified the teeth on his flywheel to eliminate the grinding, but that probably isn't something I'd personally do.
Check your starter to see if it is by Denso, if it is, try to find a Mitsubo starter and change that in. But you better do it soon, because all the grinding will slowly damage the teeth on the flywheel, and it will get to a point that the damage is too much, even a Mitsubo starter won't even fix the problem
