need help on vaccum canaster
Old May 12, 2004 | 03:31 PM
Jagolas's Avatar
Default need help on vaccum canaster
ok i just swapped my d16z out for a jdm d15. on the im from the d16z a line goes to the vaccum canaster. the jdm 15 doesn't have the same port on the im. do i just need to plug it off or what. i have the hook up just hangin in by bay, and i am wonderin if this is hurting my perfromace. do i just need to plug the hose coming out of the canaster or leave it? anyhelp is appreciated. thanks
Old May 12, 2004 | 04:04 PM
I'll cut ya!'s Avatar
Default Re: need help on vaccum canaster (jagolas)
the point of the carbon canister is to reduce the smell of gas in your engine bay or some jazz.
if you block that one hole off you should be fine.
Old May 12, 2004 | 04:09 PM
Jagolas's Avatar
ok got pics
[C:\DocumentsandSettings\Owner\Desktop\MyPics\2004-05(May)\IMoooo93.Jpg][/IMG]
Old May 12, 2004 | 04:10 PM
Jagolas's Avatar
and pics screwed up
Old May 12, 2004 | 04:12 PM
Jagolas's Avatar
ok what about sensor that is hooked up to vaccum hose?
[C:\DocumentsandSettings\Owner\Desktop\MyPics\2004-05(May)\IM000093.Jpg][/IMG]
Old May 12, 2004 | 04:14 PM
Jagolas's Avatar
ok pics still not working
Old May 12, 2004 | 04:18 PM
Jagolas's Avatar
ahaha i was using wrong address. i will postem later. anyway's there is a sensor that goes to the vaccum conector, what is it?
Old May 12, 2004 | 04:25 PM
_BEN_'s Avatar
you have to host pics online to post them here.
go to http://www.imagestation.com
The reason why you dont have a hose for the charcol canister is because jdm cars dont have them. So just plug it or figure out how to hook to up to your engine if you have to worry about emmisions testing. Because they may hit you on that.
Old May 12, 2004 | 04:31 PM
Jagolas's Avatar
Default Re: need help on vaccum canaster (_BEN_)
yeah i just signed up with http://www.we-todd-did-racing.com so picks will be up tonite. however, i don't have emissions in tn so that's no the prob. but there is some kindof sensor with wires hooked up to the vaccum line that went from the im to the canaster what is that?
Old May 12, 2004 | 04:36 PM
Jagolas's Avatar
ok try this
Old May 12, 2004 | 04:37 PM
Jagolas's Avatar
well still didn't work, dangit, i will fix it tonite, then i will figure out what sensor im screwin with
Old May 12, 2004 | 04:39 PM
Jagolas's Avatar
ok last time
[http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMzkxOTcwNnM0MTNkZmQzMXk1NDE%3D.jpg][/IMG]
Old May 12, 2004 | 04:40 PM
_BEN_'s Avatar
must be a bad link
Old May 12, 2004 | 06:27 PM
built562's Avatar
i will tell you exactly what you are talking about, its the very top hose from the charcol canister that says #5 on it right, it goes to the evap purge solenoid that jdm motors do not have, the car will run fine with out it, and yes if you want to use it you will need to make a vacuum port on the intake manifold. i just did this for my car because i needed it to pass state ref to get BAR sticker
Old May 12, 2004 | 07:09 PM
heel_touge's Avatar
Default Re: need help on vaccum canaster (akumaracer)
my friend and i just swapped out a jdm b16 throttle body for a usdm LS on his jdm b16(because the stock TPS was destroyed). the usdm has no nub for the coal box hose but we plugged it up. right now the car idles like your standard vaccum leak. bouncing from 800-1300 rpm at idol. any ideas where there maybe a vaccum problem to fix??
Old May 12, 2004 | 07:34 PM
suspendedHatch's Avatar
Default Re: need help on vaccum canaster (1slowcivic)
Don't tap a new hole, just use a t fitting on an existing line, like your FPR vacuum line. It will help your gas mileage and it doesn't hurt performance, probably helps it. It's fuel purge, it collects evaporated fuel from when your car is sitting and lets them into your engine when you're cruising.
Old May 12, 2004 | 07:38 PM
Jagolas's Avatar
Default Re: need help on vaccum canaster (shaundrake)
ok so the sensor means nothing right? and if i use a t fitting what do i do with the sensor? that makes sense but were do i need to hook it up to?
Old May 12, 2004 | 07:46 PM
Miracle Swap16's Avatar
The charcoal canister in the engine bay is the vent for the gas tank. Back in the day as gas expanded in the tank Hydrocarbons needed to vent so they were just vented into the atmosphere. Now a days there are laws against stuff like that so vacuum from the intake manifold is used to pull the extra HC's from the gas tank to be stored into the charcoal canister. During highway crusing with good vacuum in the intake manifold these extra HC's are sent into the motor and are burned. You don't really want to plug the Evaperative Purge canister, you want to either find a ported vacuum source on the intake manifold or just let it be open because your gas tank will not be able to vent.
Old May 12, 2004 | 07:50 PM
Jagolas's Avatar
Default Re: need help on vaccum canaster (Miracle Swap16)
well that is what it is doin, the mechanic who installed the motor wasn't sure what it was for so he left it hangin, and i have too for like a month, but i was just curious on what it's function is.
natedawgg94
Dec 20, 2007 05:13 AM
JDM_Risa
Aug 25, 2005 08:42 PM
wekillyou
Jul 23, 2005 12:30 AM
Layziebtnh055
Jun 5, 2004 06:50 AM
