MAINT REQD light...
96 gs-r....
is there a set of codes for the maint reqd light, and if so how to get the codes themselves and how to find out which the car is putting out to make the light come on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicyfn »</TD></TR><TR><TD CLASS="quote">yeah go search...type in "maintenance"</TD></TR></TABLE>
that was a jackass answer... if its ur maint light then dont worry about it.. it has no codes... just a timing thing that acura put on there to tell u to bring the car to them to spend money.. it just means u might need maintaince like plugs wires etc.. nothing big.. now if its a check engine light then look at the top of this forum and read the thread i started , it tells u how to check the ecu code and waht it means
i am in need of brakes, and i have a feeling the abs might have tripped the light, is there any way to tell for sure? I also have a fear that it may be the timing belt, do i have to just plug it into a scanner?
if its a main light then that has nothing to to with timing belt or abs... abs light will go off if there is something wrong with that... main light has nothing to do with codes.... that would be the check engine light.... thers a box under the dash to the right of the sterring wheel with a square button on it... cut the ignition on too acc, and press and hold that button for 10 secs.. the main light will go off... how many miles do ub have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">
that was a jackass answer... </TD></TR></TABLE>
why do you think that was a jackass answer...atleast i didnt just say "go search"
there were alot of threads about this and i think he would have found it quicker if he searched...just freaking helping him out...
there were alot of threads about this and i think he would have found it quicker if he searched...just freaking helping him out...</TD></TR></TABLE>
because that was just a waste of time and forum space... Anyways just reset it no big deal.
