HOW TO SMOKE TAILLIGHTS????
i want to smoke JUST the brake and turn signal area of my taillights, but i dont know how to go about doing this. ive search and came up with nothing. does anyone know how i should do this, or if there are any places where i could buy already smoked lights. thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue »</TD></TR><TR><TD CLASS="quote">remove taillight, grab a big rolling paper, roll up the doobie, sit back and enjoy</TD></TR></TABLE>Hahah! I was like "WTF?! he try'na say?" Took me a min. to get what you was try'na say.
how many people were going to post this, and then this guy ruined it for everyone
remove taillights...bake in oven for about 7 min at 210 degrees....and then try to pull the lense off. if glue isnt melting....bake a little more in small intervals. spray paint the part you want smoked with transparent smoke colored spray paint...usually found in hobby stores. melt glue again by baking and re-assemble
you might want to add some silicone when you reassemble them so it doesnt leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dj Villain »</TD></TR><TR><TD CLASS="quote">remove taillights...bake in oven for about 7 min at 210 degrees....and then try to pull the lense off. if glue isnt melting....bake a little more in small intervals. spray paint the part you want smoked with transparent smoke colored spray paint...usually found in hobby stores. melt glue again by baking and re-assemble
couldnt you just spray them on top and not have to take them apart?
</TD></TR></TABLE>couldnt you just spray them on top and not have to take them apart?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DagYo! »</TD></TR><TR><TD CLASS="quote">how many people were going to post this, and then this guy ruined it for everyone</TD></TR></TABLE>
I was - That was the FIRST thing that came to my mind!
I was even going to try to photoshop a picture of someone smoking a taillight... but I have to much work to do
my friend used the spray that you can get at hobbie shops. he just sprayed a light mist on the lights, comes right of with alchohol and heavy scrubbing just in case you change your mind.
easiest way to do that is to use transparent vinyl. Thats how i did my taillights, and the best thing about using the vinyl, if you get tired of the look, you can take it off. Best of all, during the bright sunlight, the amber turn signal stills lights up very clearly. I work at a sign shop, so i have access to this vinyl. I used the dark gray on my car, but there is also a light gray that you can use. pm me if you are interested in it.
my old car r.i.p.
my old car r.i.p.
