i'm confused about b16 axles, someone help
Old May 12, 2004 | 12:00 PM
vitrox's Avatar
Default i'm confused about b16 axles, someone help
Okay, the car is an 89 crx si. I ordered a b16 w/y1 tranny from hmotorsonline. It comes with the siR axles i believe. Will these bolt right up on my car or am I going to have to get different ones.. I'm also confused on the final drive on the transmission..
the y1 is 4.266
j1/s1 is 4.400
what will the rpms be in 5th gear at 70mph with each tranny? anyone know? I know there was a calculator for these transmissions somewhere online but I can't remember where I saw them.
Old May 12, 2004 | 12:10 PM
sikcrx80's Avatar
what are u going for in ur set up.. n/a or F/I
well my cars 5th gear at 100 km it is like 4000 rpm's and i have S1 tranny
Old May 12, 2004 | 12:22 PM
vitrox's Avatar
Default Re: (sikcrx80)
eventually it will be turbo'd, but not till next year.
i'll probably get a hydro tranny for that though.
wtsexton's Avatar
Default Re: i'm confused about b16 axles, someone help (vitrox)
The pass SiR will work but the drivers side will not. The Y1 intermediate shaft will require hybrid drivers side axle (y1 intermediate shaft is about a inch too long). Best thing to do would be to get a 90-93 Integra intermediate shaft and run 90-93 axles. You could order axles from hasport or raxles but to me thats way to expensive and if you break one you have drop $400 on new ones rather than just going to autozone and picking up one for $60.
Old May 12, 2004 | 02:47 PM
c8r9x's Avatar
Default Re: i'm confused about b16 axles, someone help (wtsexton)
i agree. do what i did sell the siR axles and buy the integra axle set up (axles, halfshaft). Then the siR axles become someone elses problem.
Old May 25, 2004 | 04:17 PM
vitrox's Avatar
stupid questions, but wtf is a half shaft? anyone got a pic?
Old May 25, 2004 | 04:21 PM
JoshDM's Avatar
Default Re: (vitrox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vitrox &raquo;</TD></TR><TR><TD CLASS="quote">stupid questions, but wtf is a half shaft? anyone got a pic?</TD></TR></TABLE>
the half shaft is an extension from the trans to the drivers side cv shaft
b series motors have the half shaft because it helps to eliminate torque steer from having two different length shafts
Old May 25, 2004 | 04:28 PM
vitrox's Avatar
Default Re: (JoshDM)
so thats why my stock d16 had really bad torque steer when i mashed the gas?
is the half shaft a part that is replaced regularly like the axles? or is it a non wearing part?
Old May 25, 2004 | 05:10 PM
DC 2's Avatar
This is what you need:
http://cayotic.com/Axles.html
Old May 25, 2004 | 10:57 PM
vitrox's Avatar
Default Re: (EH3B18B)
still, does anyone know if i can just go buy a new intermediate shaft from a 90-93 integra, then use those axles?
Old May 25, 2004 | 11:30 PM
wtsexton's Avatar
The only SiR axle you can use is the pass side.
Old May 26, 2004 | 12:16 AM
vitrox's Avatar
Default Re: (wtsexton)
i mean buy the 90-93 IS, then use the 90-93 axles? anyone know?
Old May 26, 2004 | 08:10 AM
c8r9x's Avatar
ok basically just get the whole 90-93 integra axles set up including the half shaft
Old May 26, 2004 | 10:04 AM
X-Static's Avatar
do any of you actually know wtf your talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">The only SiR axle you can use is the pass side. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">The pass SiR will work but the drivers side will not. The Y1 intermediate shaft will require hybrid drivers side axle (y1 intermediate shaft is about a inch too long). </TD></TR></TABLE>
im using my SiR axles with my y1 in my crx and my car drives like a champ
Old May 26, 2004 | 11:41 AM
vitrox's Avatar
Default Re: (X-Static)
so no new axles till these are broke then? thats good news to hear.. less money to spend right away..
Old May 27, 2004 | 01:12 AM
DC 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vitrox &raquo;</TD></TR><TR><TD CLASS="quote">i mean buy the 90-93 IS, then use the 90-93 axles? anyone know?</TD></TR></TABLE>
man, that link I sent you wasnt axels for sale. It will answer your questions about any B-series EF axel question you might have. Read it. Its Good **** yo
Hasport wrote it so it is creditable.
Old May 27, 2004 | 06:56 AM
crx_88_si's Avatar
what mount kit are you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static &raquo;</TD></TR><TR><TD CLASS="quote">do any of you actually know wtf your talking about?
im using my SiR axles with my y1 in my crx and my car drives like a champ</TD></TR></TABLE>
Old May 27, 2004 | 07:19 AM
slowpokesi's Avatar
when i got my siR axles,
they were busted, so i had to go buy new integra axles.
Old May 27, 2004 | 09:10 AM
vitrox's Avatar
I got a hasport mount kit coming with my motor. I would still feel better if someone with the Y1 setup would chime in and say what they are running for axles, that hasport page has a lot of info, but it doesn't give me a definite answer in there..
someone needs to just make a chart.
Old May 27, 2004 | 09:22 AM
CyniKal.Mindset's Avatar
for some people the b16a axles work fine with their car and then some people have to use integra axles...I dunno if it depends on the tranny or what...cuz my buddy's swap the axles that came with the swap the driverside was 2" too long and a 90 integra axle seems to be a perfect fit
I too would like the low down on this problem...this is also another reason why I'm just droppin a ZC in my civic
Old May 28, 2004 | 09:06 AM
X-Static's Avatar
Default Re: (CyniKal.Mindset)
im using the hasport EFb1 mount kit, and im running an S1...maybe thats why mine fit...tho they did last long...theyre already busted so ill be getting some new teg axles asap
Old May 28, 2004 | 09:21 AM
90civichbsi's Avatar
im running the hasport kit, and 90-93 integra axles as well as the 90-93 integra intermediate shaft... fits perfect and i can get lifetime warranty replacement axles at autozone for 65 bucks.
and someone asked about the intermiate shaft being a wear item... its not a wear item like axles, it should last the life of the vehicle, but just like all moving parts, they may eventually fail.
the Y1 tranny comes with a 4.266 final drive, it should be good for turbo. even with that final drive, its a bit shorter than the hydro gsr tranny. if i remember correctly it should top at at about 146 @ 8k while the gsr tops out at 156 @ 8k and the s1 @ 136 @ 8k this is with 22.8" tires
philkehn
18
May 28, 2007 08:24 AM
90civSi
Dec 7, 2006 03:52 AM
fkncivic
May 15, 2005 11:02 AM
SiZ
18
Jan 31, 2004 02:25 PM
gatesrex91
Dec 17, 2003 08:52 AM
