Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Effect of offset on handling
Old May 12, 2004 | 10:44 AM
charjacq's Avatar
New User
Default Effect of offset on handling
What is the effect of the offset on handling? I am looking at 15in wheels with 45 offset on a 91 civic. I believe the stock offset is somewhere around 40.
Any input?
Old May 12, 2004 | 11:29 AM
chad's Avatar
Moderator
Default Re: Effect of offset on handling (charjacq)
lower number for offset means wheels will stick out further thus giving you "WIDER" track.....it helps....but i don't think it would help you or ME rather i don't think you or i would notice....we aren't good enough....
i have run a 35 offset on my civic with no problems
Old May 12, 2004 | 11:48 AM
Greyout's Avatar
Default Re: Effect of offset on handling (chad)
IIRC:
One thing you will notice, is as the offset changes, so does the scrub radius (I think thats what its called.) Basically, How far the center of the tire is from the center point of the rotation when you turn the steering wheel (imagine a line from the top ball joint to the bottom.) The scrub radius has an effect on steering forces: a higher offset will cause the wheels to track back to center more, like when you let go of the steering wheel... a lower offset will cause the car to continue pulling in the direction the wheel is turned when you let it go.
I've also read that when the scrub radius is pretty much zero'ed out, that you get a car that feels like it wanders, without much feedback at all.
Old May 12, 2004 | 03:37 PM
Audipwr1's Avatar
scrub radius is changed correct
Old May 13, 2004 | 10:16 AM
crxfanatic's Avatar
New User
88-91 Civics and CRXs have a factory offset of 45mm. The 84-87s have a 40mm backspace.
Old May 13, 2004 | 10:23 AM
Tyson's Avatar
GRM had a tirerack column that explained difference in offset pretty well in a recent issue. might wanna check that.
thomasw91
Nov 6, 2009 08:40 AM
honda_guy58
Jan 15, 2009 12:47 PM
95blackEG
Oct 28, 2008 11:51 AM
lsegcoupe
Apr 2, 2007 09:16 PM
Yogi bear
Jun 29, 2001 08:20 PM
