At what engine temperature should OIL LEVEL be checked at......?
Old May 12, 2004 | 09:59 AM
TypeRuz's Avatar
Default At what engine temperature should OIL LEVEL be checked at......?
Yesterday, I changed my oil and I used 4.4 quarts total. I let the oil-burning Mobil 1 drain out for a good half hour before I added my new Amsoil....which btw is awesome stuff. The engine was noticably smoother at idle. (More of a review after first oil change.)
I later checked the dipstick five minutes after parking the car from a long drive and it was about 1 mm above the MAX line. That's usually where I like it in case of any oil usage.
This morning I did a quick check again with the engine bone cold and it measured about 4-5 mm above the MAX line.
I know the oil settled over night causing it to give a higher reading.
So, which reading should I go by?
Did I put too much oil? (i usually put 4.4 Q and it works out fine.)
Could any possible damage occur? If so, what?
TIA!
Old May 12, 2004 | 10:03 AM
.RJ's Avatar
.RJ
Default Re: At what engine temperature should OIL LEVEL be checked at......? (TypeRuz)
Owners manual says 4.2quart....
I never go by how much i'm putting in, always reference the dipstick.
Old May 12, 2004 | 10:07 AM
1GreyTeg's Avatar
Go by the cold reading as in right before you start it the first time in the morning on a level surface.
At the high mark or just a hair under is fine.
I think the idle is in your head.
Old May 12, 2004 | 12:38 PM
Justin Klemgold's Avatar
The idle is in his head IMO...I didn't notice a change when I switched back to Amsoil after a M1 change with 24k on the clock.
kccord
Dec 14, 2009 03:27 AM
Nameless Warrior
May 11, 2007 08:31 AM
return_2020
Honda Civic (2001 - 2005)
Sep 2, 2006 06:44 PM
speedymon
Nov 29, 2004 05:28 PM
JSMC
Aug 3, 2003 07:55 AM
