Del Sol seats in my hatch?
Old Nov 5, 2001 | 09:48 PM
hondacivic4g's Avatar
Default Del Sol seats in my hatch?
Does any one know how hard it would be to put Del Sol seats in my H/B. Or any web pages that give instructions on the swap? If so i'd appreciate any info on this swap.Thanks -Later
Old Nov 6, 2001 | 07:10 AM
Mace88Si's Avatar
New User
Default Re: Del Sol seats in my hatch? (hondacivic4g)
If the floor plan is the same setup as an 88 CRX...it not that difficult. The org. rails were not used, since the del sol rails are wider. I had customize metal extensions to reach the org. bolt holes. Only three are used at this time. If you have access to a wleder, you can fabricated custom brackets. I don't, so mine sits on the three bolts. I suggest using the front mounts as the weight will hold you back in the seat while driving. They def. hold you in your place under hard driving. they cradle your back and shoulders. Hope this helps.
Old Nov 6, 2001 | 01:53 PM
Redsun's Avatar
I know the Integra seats will fit perfect.
Old Nov 6, 2001 | 01:56 PM
FSTRex's Avatar
Default Re: Del Sol seats in my hatch? (Redsun)
Which integra seats will fit in a 90civic hb??
Old Nov 7, 2001 | 02:48 PM
naturalhoosier's Avatar
New User
Default Re: Del Sol seats in my hatch? (99Sleeper)
I put 93 GSR seats into my 88 DX Hatch, but they didn't fit perfectly. Took some modification.
Old Nov 10, 2001 | 06:16 AM
Redsun's Avatar
sorry, my mistake, he has the 90 hatch, i'm referring to the EG civics.
Old Nov 10, 2001 | 09:39 PM
Pissoff's Avatar
like that?
Old Dec 16, 2001 | 11:19 AM
nfn15037's Avatar
Default Re: Del Sol seats in my hatch? (Usdm ED9)
What about del Sol seats in a DC? Im getting some today and want to know how they'll fit in my Integra. TIA
Old Dec 16, 2001 | 01:56 PM
eg6ajk's Avatar
Default Re: Del Sol seats in my hatch? (nfn15037)
as far as EG and DC:
two mounts will fit without a problem....lets start with with back mount (one closer to the outside/door), enlarge the hole or move it down about 1.5 cm or so....bend it as well so it will look like the GSR mount.....next is front mount one next to the cnt console....with this one you will need to be creative (i cut mine out and added a huge metal washer to go over it....
Old Dec 16, 2001 | 05:45 PM
nfn15037's Avatar
Default Re: Del Sol seats in my hatch? (eg6ajk)
Are these really lower than GSR seats?? The whole reason im getting em is so my helmet wont hit my roof and ive been told these are 2-3 inches lower. Can anyone confirm or deny this???
Old Dec 16, 2001 | 05:58 PM
brad.'s Avatar
yep they are lower...my friend has em in his DC
Old Dec 16, 2001 | 07:59 PM
brian.edge's Avatar
Default Re: Del Sol seats in my hatch? ([626]JDM-b16a-EF9)
well what would i have to do to get theses in my ef, i have a friend that is gonna sell me both of his but i dont know if they will work?
feelmyarmsbreak
Jul 10, 2011 08:57 AM
x_tc-Dae
15
Dec 30, 2004 07:08 PM
JJW
Jul 14, 2003 02:07 PM
LSVtecEK1
Jan 23, 2003 09:34 PM
95excoupe
14
Jan 26, 2002 12:04 PM
