ls non-vtec hp options?
anyone have some good tips on a way to run as well and get as many r's
as a vtec without having to go there!!
i already assume cams, springs, intake manifold how else could i really build up my head or where can i find info on this? nothing against vtec it's just that every has it...i'm trying to stray a little but still rip!!
thank you very much i have a 95Ls
i tried a search and was not very successful, everything came up vtec this vtec that
could you recommend any key words maybe i'm having no luck
thank you
thank you
i'm also not trying to go broke in the process..
i have priced superchargers and they all seem to be around 2500.00 for starters
and it only brings you up to about 190 hp.
if you piece together your own turbo setup it's pretty affordable. a lot more hp per $ than the na route.
http://www.cse.uconn.edu/~yele....html
Ive spent well over 2000$ on my gsr doing the na route. and just under 1000 for my 1.5l crx with fi. the crx is just as fast as my gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrxracing »</TD></TR><TR><TD CLASS="quote">i'm also not trying to go broke in the process..
and it only brings you up to about 190 hp.</TD></TR></TABLE>
Ha ha. That's hilarious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA »</TD></TR><TR><TD CLASS="quote">hahah sadly im sure they will sell 1000's</TD></TR></TABLE>
They probably will, and its a shame. Ls owners should be proud of their cars, it dosen't have vtec but it's still a good car and does have potential.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshowallgo »</TD></TR><TR><TD CLASS="quote">turbo!!! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95integralshere »</TD></TR><TR><TD CLASS="quote">i agree. the ls tranny is in my opinion, better for a turbo setup. Turbo ls's make very fast cars. and they can still be reliable.</TD></TR></TABLE>
please explain why... im gonna have to disagree
i was just stating that for his situation. As i read it back, i see that i typed what i was thinking wrong. He already has an ls tranny, it wouldn't be worth the cost of getting a gsr tranny. That is unless he has alot of money for this project. Otherwise there are more cost effective ways to get power.
The ls engine itself isn't any better for turbo, compression ratio set aside. The longer gearing of the tranny is better though. With a turbo you create a wider more useful powerband, therefor longer gearing would be more suited. Thats the same reason a lot of faster V8s run powerglide trannys. They have such a broad torque curve they can use only 2 gears and get away with it. Although I don't think you were asking me to explain haha.
ls power lies in a ported head, whether its na or fi. start there. if you wanna go boost find some cams you think might work for both and run those. im doing this and i chose rm L21 regrinds. im na now and will booost the same motor later on. the compression could be increased with a thinner headgasket to boost na power. highly recommend a better tranny than the ls tranny. you will be faster with that na or fi. im using a close ratio b series tranny with a 4.26 final drive so i get the benefit of the longer gearing of the ls without the loose *** gearing. you are going to be faster with the close gearing.
