Disc Brake conversion (Is 99-00 Si and GSR the same)
Old May 12, 2004 | 07:14 AM
loudsubz's Avatar
Default Disc Brake conversion (Is 99-00 Si and GSR the same)
I might have a deal on a 99-00 Si brake conversion (F+R). Is it the same as the GSR? In terms of bolting right up on an EG?
I have looked but havnt found anything about it, just about GSR and ITR etc.
thanks.
Old May 12, 2004 | 07:57 AM
Filliam H. Muffman's Avatar
Default Re: Disc Brake conversion (loudsubz)
rear disc brakes are the same.
as far as the front i *THINK* the si are different. and they might not fit on an EG, but im pretty sure they will, even with a little modification
Old May 12, 2004 | 08:02 AM
teamsol's Avatar
yah im the same spot you are right now. Ive been searching for a little and havent found anything.. ill keep at it though
Old May 12, 2004 | 08:03 AM
bbarbulo's Avatar
considering there are EKs with ITR 5 lug setups, that should tell you that the parts are interchangable, even though the part numbers differ.
Old May 12, 2004 | 09:18 AM
HyBriDcxR's Avatar
I have both front and rear 99-00 si brakes on my eh hatch. No problems here.
Old May 12, 2004 | 09:25 AM
vtecn8ive's Avatar
Default Re: Disc Brake conversion (HyBriDcxR)
Is the GSR for the f+r? I believe the GSR has a bigger caliper and rotor (on the front). Brake hoses are also different. The Si front are the same as a 96-00 EX. The GSR rear should match right up.
NIKE SB'd
Jun 13, 2006 07:49 AM
spoonishEJ1
Jul 8, 2004 10:53 AM
6SPD_EK
Apr 10, 2004 09:19 AM
Spartanic
11
May 19, 2002 09:16 PM
