Disc Brake conversion (Is 99-00 Si and GSR the same)
I might have a deal on a 99-00 Si brake conversion (F+R). Is it the same as the GSR? In terms of bolting right up on an EG?
I have looked but havnt found anything about it, just about GSR and ITR etc.
thanks.
thanks.
Re: Disc Brake conversion (loudsubz)
rear disc brakes are the same.
as far as the front i *THINK* the si are different. and they might not fit on an EG, but im pretty sure they will, even with a little modification
yah im the same spot you are right now. Ive been searching for a little and havent found anything.. ill keep at it though
considering there are EKs with ITR 5 lug setups, that should tell you that the parts are interchangable, even though the part numbers differ.
Re: Disc Brake conversion (HyBriDcxR)
Is the GSR for the f+r? I believe the GSR has a bigger caliper and rotor (on the front). Brake hoses are also different. The Si front are the same as a 96-00 EX. The GSR rear should match right up.
6SPD_EK
04-10-2004 09:19 AM
