Honda S2000 Honda S2000
TIRES for 2K3 S2K
Old May 12, 2004 | 06:59 AM
ICANTDRIVE55's Avatar
Default TIRES for 2K3 S2K
The original Bridgestones on the back of my '03 S2K have turned up smooth after 15K miles. I am surprised this happened so quick. The performance of these tires was very good for many months. Can anyone suggest a replacement tire for the rear that would have at least stock performance but better milage?
Old May 12, 2004 | 07:15 AM
blacks2000's Avatar
Default Re: TIRES for 2K3 S2K (ICANTDRIVE55)
I don't think there is one that will perform as well as the S02, and last longer.
If you get rears with a different tread pattern make sure you change the fronts also or the car won't handle right. I tried mixing So3 rear with S02 front, and it handled like crap.
Also, if you get anything other than a stock s02 for the rear, you will need a 245.
Old May 12, 2004 | 11:40 AM
jolt-tsp's Avatar
Default Re: TIRES for 2K3 S2K (blacks2000)
What my brother did is bought a separate set of wheels to put hoosiers/victoracers on for racing, and then just bought crap for the road. I think he's running fk451's in the front and ecsta 712's in the rear these days
Old May 12, 2004 | 12:10 PM
steven975's Avatar
Default Re: TIRES for 2K3 S2K (jolt-tsp)
on my GSR i used potenza 730 and 750's.
they are W rated, summer, and last over 20K. good grip, too.
the S I bought has 910's which I'm not happy about. i'll get 750's when the time comes.
Old May 12, 2004 | 01:57 PM
cmdr430's Avatar
i just bought a set of work wheels and installed a set of falken grb 451's, they handle pretty nicely and are not very expensive....
Old May 12, 2004 | 07:02 PM
eg_nezay's Avatar
Default Re: TIRES for 2K3 S2K (cmdr430)
Seems like they dont make the Azenis for you S2k owners?
Bump for a friend in need of some input.
BTW- Welcome to the site PZ!
Old May 13, 2004 | 07:27 AM
Thanks, I didn't know that what seemed to be a small change could have a big perf impact.
Old May 13, 2004 | 07:34 AM
Default Re: TIRES for 2K3 S2K (eg_nezay)
THEY DO!!! but its a special order item by the local shops. I'm checking on this now.
Thanks for the suggestion.
Old May 13, 2004 | 08:18 AM
eg_nezay's Avatar
Here is a good find that I found in another thread;
http://www.hondaautomotivepart...WHEEL
$118 for fronts
$128 for rears
For the S02's.
And some helpful info;
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I really like the Toyo T1S tire. I have those on my 17s. I do not know if they make an OEM replacement though.
p.s. The 225 rears is more like a 245 in a different brand. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Agreed...so if you ever change the model or brand of your tires...go one size bigger. Fronts up to 215, and rears up to 245. It has to do with the design of the tire for the OEM fitment on the S2K...Bridgestone made the contact patch "bigger" for the OEM S2K. </TD></TR></TABLE>
Old May 13, 2004 | 09:09 AM
Formula 1's Avatar
im thinking get 15" spoons then azenis?
Old May 13, 2004 | 09:19 AM
blacks2000's Avatar
Default Re: TIRES for 2K3 S2K (SikCivic)
15's would look dumb
Old May 13, 2004 | 09:25 AM
Formula 1's Avatar
they look dumb on the track, who cares about looks
Old May 13, 2004 | 11:02 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic &raquo;</TD></TR><TR><TD CLASS="quote">im thinking get 15" spoons then azenis?</TD></TR></TABLE>
15" wheels are too small and wont clear the calipers.
Old May 13, 2004 | 11:10 AM
Formula 1's Avatar
Default Re: TIRES for 2K3 S2K (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
15" wheels are too small and wont clear the calipers. </TD></TR></TABLE>
sorry i did not know it wouldnt clear the calipers, obviously that idea is crap
anybody try these tires or know anything about them?
http://www.tirerack.com/tires/...dex=1
seem to be better rated all around than the s02, especially treadwear
Old May 13, 2004 | 11:21 AM
evil vapor's Avatar
seem to be better rated all around than the s02, especially treadwear</TD></TR></TABLE>
they still wear fast. Driving habits will dictate how quickly the rear tires wear in this car. If you drive your car spirited on the public roads, get the so2's and you'll be happy, the grip is worth it. Otherwise, get the cheapest hardest tires available, federals or whatever as they'll last forever but you can't expect grip out of them for spirited driving.
Old May 13, 2004 | 06:35 PM
Formula 1's Avatar
they still wear fast. Driving habits will dictate how quickly the rear tires wear in this car. If you drive your car spirited on the public roads, get the so2's and you'll be happy, the grip is worth it. Otherwise, get the cheapest hardest tires available, federals or whatever as they'll last forever but you can't expect grip out of them for spirited driving. </TD></TR></TABLE>
to mean they seemed ot have better all around ratings especially tire wear, i havent tried either just thought i might make a suggestion
Old May 14, 2004 | 05:47 AM
Marble's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICANTDRIVE55 &raquo;</TD></TR><TR><TD CLASS="quote">THEY DO!!! but its a special order item by the local shops. I'm checking on this now.
Thanks for the suggestion.</TD></TR></TABLE>
THEY DO what? Falken has the sizes needed to fit the stock S2K wheels? If so fill us in!!
Old May 14, 2004 | 11:52 AM
Formula 1's Avatar
Default Re: TIRES for 2K3 S2K (ATXS2K)
azenis or a032r? i would go s02 or 203 daily and a032r track. not a huge fan of falken
Old May 18, 2004 | 06:18 PM
evil vapor's Avatar
to mean they seemed ot have better all around ratings especially tire wear, i havent tried either just thought i might make a suggestion</TD></TR></TABLE>
your suggestions are more than welcome, no worries. The problem arises when fitting the car that came with pretty damn good tires with less than ideal tires due to cost. If the car is going to be driven tamely behind the hands of a new driver, then the lower cost tires will be fine. But if the same driver chooses the cheaper tires, they will be surprised by the lack of grip if they go on "spirited" drives.
Old May 19, 2004 | 07:41 AM
I called a local shop to check on availablity of Azenis for S2K. Initially they said no prob, but when I got there... no azenis. so, evidently you were right in the first place. No Azenis for S2k.
Old May 19, 2004 | 07:48 AM
EG:
I'm gonna check out the TOYO's and go a size bigger. Thanks for the info.
icd55
Old May 19, 2004 | 01:28 PM
StinkyTofu's Avatar
The kumho ecsta MX tires are supposedly pretty good for dry weather traction and also has the correct sizing for the S2k. Based off personal reviews, it seems that these are an excellent alternative to the S02's if budget is a concern. They still don't beat out the S02's. But for about half the price, who can complain?
I'm considering replacing all four of my tires with the MX's but i really want to get S02's. I bought my car used and have still not yet experienced my car with 4 S02's on .
Old May 19, 2004 | 01:30 PM
Formula 1's Avatar
Default Re: TIRES for 2K3 S2K (StinkyTofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">The kumho ecsta MX tires are supposedly pretty good for dry weather traction and also has the correct sizing for the S2k. Based off personal reviews, it seems that these are an excellent alternative to the S02's if budget is a concern. They still don't beat out the S02's. But for about half the price, who can complain?
I'm considering replacing all four of my tires with the MX's but i really want to get S02's. I bought my car used and have still not yet experienced my car with 4 S02's on .</TD></TR></TABLE>
If you want S02's or MX's PM me
Old May 25, 2004 | 06:02 AM
00MRSi's Avatar
I think you should wait a little longer and save up for the S02s.
Old May 25, 2004 | 06:15 AM
Mr. Bagel's Avatar
The Ecsta MX's are just that... "pretty good for dry weather traction". However, they are not "fantastic", "great", nor even "sufficient" for this car IMO. Go with some S03's or S02's. DO NOT take the advice of going to 215's in the front. That isn't a proper tire size. It's 205's in the front, or 225's with a front bar in the front - and 245/45's in the rear for anything other than OEM S02's.
