Koni/GC -- Suspension Tuning
I have a pretty standard setup now:
Ground Controls - 400lbs Front, 500lbs Back
Koni Shocks
205/50/15 Azenis on stock ITR rims
I'm wondering how everyone else who has this setup has theirs tuned(for track and for street).
Specifically:
- What tire pressures
- What ride height(is the backend higher/lower/equal to the front)
- What shock settings do you use for the street, and what for the track?
- What toe settings do you use?
Koni Shocks
Specifically:
Take some white shoe polish and run a mark across the tire (up the sidewall and across the tread), then go out and see what is rubbed off (to see how much of the tire is touching the road). This will be one way to adjust your tire pressures.
For ride heights, everyone will say "corner weight" ... right now I just have mine with the front lower for better aerodynamics (along with other frontal adjustments so the air flows quite nicely).
Full stiff, nuff said.
Toe should be 1/16th out (need to doublecheck), but like most things, it can be up to the driver too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">Toe should be 1/16th out (need to doublecheck), but like most things, it can be up to the driver too.</TD></TR></TABLE>
a lot of us run 1/8th toe out, or 1/16th per side in the front.. 0 rear..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar »</TD></TR><TR><TD CLASS="quote">
a lot of us run 1/8th toe out, or 1/16th per side in the front.. 0 rear.. </TD></TR></TABLE>
derrr, yeah that's what I meant....you're right.
I've also noticed when I sit in the car, the driver side drops around 1/8th inch front and back.
Is it generally a good idea to compensate for this when setting the ride height(making the driver side sit 1/8th higher)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond »</TD></TR><TR><TD CLASS="quote">
- What tire pressures: 40f/30r
- What ride height(is the backend higher/lower/equal to the front): finger of gap front/rear
- What shock settings do you use for the street, and what for the track? almost full stiff in front, middle in the back
- What toe settings do you use?: 1/8th" toe out front, 0 rear</TD></TR></TABLE>
This is on a 92 Civic Si, but I have a 22mm rear bar, so it's more or less appropriate for you to look at. 380/450 spring rates and a 21mm bar in front.
yellow blur
May 12, 2003 03:49 PM
EGO
Apr 22, 2003 02:58 PM
