Q's on Throttle Body's???
Old Nov 5, 2001 | 08:41 PM
REDBARON's Avatar
Default Q's on Throttle Body's???
Hey guys, does any Throttle body from a D-series engine bolt on? I'm talking about a 2nd gen CRX Si Throttle body on a Sohc Vtec intake manifold. Will this still work??? Thanks for the help guys.
Old Nov 5, 2001 | 09:15 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Q's on Throttle Body's??? (VTECHatch)
The 88-91 and 92+ Civic intake/TB have a different bolt pattern.
You can use the Z6 intake/TB on the A6 but will have to reroute the map wiring.
Old Nov 6, 2001 | 07:17 AM
solorex's Avatar
Default Re: Q's on Throttle Body's??? (Mista Bone)
the z6 throttle body has the fast-idle control mounted on the throttle body, whereas the crx has it moutned on the intake manifold, so no it will not work.
Old Nov 6, 2001 | 05:32 PM
eg6ajk's Avatar
for 92+ cars, b-series TBs bolt up...just get a 92+ LS/RS/GSR/ITR/CTR/B20B throttle body over 4mm is gained....as well as h-series, H22a/H23a, and probably some C series as well....
on the 88-91 d-series models a b16a TB (1st gen) can be done with some redrilling...my buddy did this on his ZC...not much off...get a gasket and compare, you can take it to a shop for $10-20 they will redrill it properly...
[Modified by eg6ajk, 6:33 PM 11/6/2001]
Elevorett
Apr 14, 2007 01:29 PM
BlueRex1020
Nov 5, 2006 12:42 PM
Crimson_Tide
Sep 26, 2005 08:48 PM
c0nspire
Oct 6, 2004 11:43 PM
goula SOS
Jun 24, 2003 02:53 PM
