will these CX motor parts work on a JDM D15B...?
Old May 11, 2004 | 11:55 PM
H22A EG6's Avatar
Default will these CX motor parts work on a JDM D15B...?
the TPS?
the VSS off of the cx tranny on a EX tranny?
throttle cable?
and the wire harness(it is kinda chopped can i just wire the cx one into it)?
thx youz guyz are the shizzo
Old May 12, 2004 | 07:33 AM
H22A EG6's Avatar
Default Re: will these CX motor parts work on a JDM D15B...? (H22A EG6)
maby not the shizzo if you cant answer
Old May 12, 2004 | 07:55 AM
Slammd Sol's Avatar
Wiring harness should work, but u will need to add wires for vtec and possibly o2 wires. VSS should work, as the autozone part numbers are the same for the CX and the Si engines. Check the autozone website for ur other parts to see if the part numbers match up
Old May 12, 2004 | 07:56 AM
BauleyCivic's Avatar
Risky Business
Default Re: (Slammd Sol)
Yes to all. If you use the CX harness you'll have to wire up VTEC https://honda-tech.com/zerothread?id=724252
Old May 12, 2004 | 11:27 AM
H22A EG6's Avatar
Default Re: (BauleyCivic)
cool beans
yea i got the vtec wiring post booked marked!
thx guys
egsleepercivic
13
May 4, 2008 10:12 PM
SLowCrx
Dec 16, 2003 02:27 PM
spoonlongblock
Dec 6, 2003 03:44 PM
civicracer1993
13
Mar 10, 2003 11:47 AM
b18c5eg
Dec 23, 2002 02:22 PM
