Vibration that i canot figure out
Old May 11, 2004 | 10:51 PM
Dr.PIMPer's Avatar
Default Vibration that i canot figure out
I have a 94 Del sol with a poor mans r, fully built. I have had it for about 6months now and all the sudden I have been having allot of vibrations wile driving. When I get on it in first gear it spins like another car but when I get to about 5k and after it starts to vibrate my whole car. Like my motor wants to jump out of my dam car. It also does it when I am in low mph for the gear I am in. Say im in 5th and going like 50mph, I push on the gas and it vibrates again. It is really strange I have asked everyone and no one seems to know what it is. This is what I have done to check it out so any other suggestions would be great.
1.Checked tire pressure.
2.Balanced and rotated tires
3.Allined all 4 tires
4.Changing rear motor mount (looked broken when I had the E-Brake up and let out the clutch) so still in the process of doing this.
Hopefully ill have that done in a few days so I can see if that did anything. The strange thing is, when we took the old mount out, it was fine. So I don’t know what else it could be. Were just hoping it was a bad mount and it will go away. Please help me though.... Thanks Guys
Old May 11, 2004 | 11:06 PM
JapJunkie's Avatar
Default Re: Vibration that i canot figure out (SleepnDELsol)
Most likely its the motor mount.
Old May 12, 2004 | 12:07 AM
Zerob16eg's Avatar
check your torque mounts. it is easy to strip out the holes and you will get vibrations if that happens.
Old May 12, 2004 | 09:42 AM
delpoop!'s Avatar
Default Re: (Zerob16eg)
bump
Old May 12, 2004 | 10:32 AM
moto27cm's Avatar
Axles, Hub Bearings....
Old May 12, 2004 | 03:05 PM
Dr.PIMPer's Avatar
Default Re: (moto27cm)
Yea, where are my tourque mounts at????? and it doesnt make any noise when it vibrates.. So I dont thinkit will be and axel, and the hub bearing, i dunno????
Old May 12, 2004 | 05:18 PM
moto27cm's Avatar
Torque mounts are the mounts that are attached to the front of the tranny and the front of the block.
Old May 12, 2004 | 08:04 PM
Dr.PIMPer's Avatar
A pic would be awesome lol..... I am not a to sure which one you mean. We got the rear mount in, finally!!!! We are also re-doing all the hoses and thermostat, and all the normal stuff.
Old May 13, 2004 | 04:33 AM
moto27cm's Avatar
Default Re: (SleepnDELsol)
#s 1 and 14, which bolt into 13 and 12 respectively.
Old May 13, 2004 | 09:14 PM
Dr.PIMPer's Avatar
OO I get which mount that is, i will check it. Just make sure there tight or what? Should I pull it off then re-mount it.
02K20A2Ep3
Transmission & Drivetrain
Nov 30, 2009 10:03 AM
Championship
May 9, 2008 05:18 AM
92EG8
Oct 27, 2007 03:46 AM
B18tSOL
Mar 10, 2007 01:10 PM
doghead
May 11, 2006 07:03 PM
