Brake noise I think?
Old May 11, 2004 | 10:04 PM
NickGSR95's Avatar
Default Brake noise I think?
I hear what I'm 99% sure is a noise coming from the rear driver's side brake. It's not super high pitch.. almost sounds a little bit like escaping air (hard to explain, still def. under a "squeaking" type of category). Anyways it comes during mild breaking, goes away when I step harder on the pedal, and also comes on when I hit a bump or am going over a particularly rough road.
Any comments/suggestions for what I need to replace would be great.. it's driving me insane!
Old May 11, 2004 | 11:00 PM
SynTeg's Avatar
Means your brakes are about to go out
Old May 11, 2004 | 11:31 PM
Sack Master's Avatar
Default Re: (SynTeg)
Maybe your squealer is broken and your pads are gone, or you lost a pad. Maybe you have a small rock or something caught in there. Spray some brakleen in there and see if it helps. Check your rotors, pads and anything brake related. Could be a number of things.
Old May 12, 2004 | 03:29 AM
shyboy817's Avatar
mines recently happened, i replaced brakepads..got it from autozone with lifetime warranty and it was only 16.99 it works fine..
Old May 12, 2004 | 05:42 AM
-iLLuZioN-B18C1's Avatar
Default Re: Brake noise I think? (NickGSR95)
i believe they call the shimmers (sp??) the thin metal layer may be starthing to scrape on your rotors. change the pads and see what happens.
Old May 12, 2004 | 06:31 AM
IntegraBoy04's Avatar
Default Re: Brake noise I think? (-iLLuZioN-B18C1)
I have the same problem, and i just replaced all of my rotors and pads. I can't figure out what it is.
Old May 12, 2004 | 06:39 AM
grlstockb18c1's Avatar
lol...mine was doing the same EXACT thing @ my back left brake. It was sooooo annoying--it was squeking real bad . So I replaced the pad, it was worn down so thats what was making the noise, metal to metal.
Old May 12, 2004 | 08:43 PM
NickGSR95's Avatar
Default Re: Brake noise I think? (grlstockb18c1)
Thanks guys! I'll start with pads and go from there.
corpsebesideme
Jul 1, 2013 02:09 AM
tsdenny
Oct 1, 2005 06:49 AM
lo0nY
11
Feb 20, 2005 10:57 PM
93egSIboi
Feb 1, 2005 04:51 PM
PatrickGSR94
Apr 13, 2002 09:42 PM
